[Qgis-developer] GRASS support in MSVC build
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Sat Nov 10 07:50:58 EST 2007
Thanks for the explanations.
I'll look into that Express Edition.
One last thing I'd like to know:
Will it be possible to mix GRASS binaries and libs produced with MinGW
with QGIS MSVC bins?
Thanks,
Benjamin
Jürgen E. Fischer wrote:
> Hi Benjamin,
> On Sat, 10. Nov 2007 at 11:34:05 +0100, Benjamin Ducke wrote:
>> Apologies for my ignorance, but what is the idea about having
>> an MSVC build of QGIS alongside the MinGW build? Does it not
>> cost a lot of additional effort to maintain two compiler bases?
>> Does the MSVC build have any particular advantages over the
>> MinGW build, so that we can expect the MinGW path to be
>> abandoned in the future?
> As Tim pointed out yesterday IRC on, why there is MSVC build:
> (quoted from http://logs.qgis.org/slogs/%23qgis.2007-11-09.log)
> 1) to attract the win crowd you got to give them their preferred brand of heroin
>    ie a development environment based on msvc
> 2) so far the msvc packages I made are a *lot* more compact (18mb vs 30mb for
>    openModeller)
> 3) because we can
> 4) if you are building some ms native app and want a mapping control you cant
>    easily just use the mingw libs if everything else you do is built using msvc
> 5) building with msvc has some advantages for debugging etc if you are a gui
>    addict
> 6) to attract venture capital from microsoft
> Personally apart from 6, which I'd replace with masochims, I'd second that.
> And I've to use MSVC for other windows projects anyway and find it's debugging
> and code browsing capabilities very useful.
> Additionally using different compilers can improve code quality a bit as one
> compiler might issue warnings on things the others don't catch.
>> If so, I for one will not be able to participate in the
>> development of the Win32 version of QGIS.
> Why not?  You can use the Express Edition of MSVC, which is free (as in free
> beer).
> Beeing at it, I don't know if Microsoft will continue to have free (as in free
> beer) Express Editions and alone for that reason the MinGW build shouldn't die.
> But I don't expect it too, anyway.
> Jürgen
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
