[Qgis-developer] [patch] rubberband extension
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Mon Oct 1 02:38:59 EDT 2007
Hi all
Thanks for applying the patch.
A modification in this direction is also in the advanced_editing_branch. It is
possible to remove the last digitised point with the backspace key with the
branch code.
Regards,
Marco
On Monday 01 October 2007 00:00:16 Tim Sutton wrote:
> Hi
> Marco are you going to look at this? It might be best to pass down the
> line to Martin Dobias since the rubber band stuff was done by hime
> wasnt it?
> Regards
> Tim
> 2007/9/29, Jürgen E. Fischer <jef+qgis at norbit.de>:
> > Hi there,
> > attached patch adds the ability to query the points currently in a
> > QgsRubberBand and to remove the last.
> > I use this in a plugin to avoid the need to keep track of the selected
> > points twice and to be able to take back the last entered point from a
> > context menu.
> > QgsMapToolCapture should probably be updated accordingly, but didn't find
> > the time yet.
> > Jürgen
> > Jürgen E. Fischer         norBIT GmbH               Tel.
> > +49-4931-918175-0 Dipl.-Inf. (FH)           Rheinstraße 13
> > Fax. +49-4931-918175-50 Software Engineer         D-26506 Norden
> >      http://www.norbit.de
> > norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> > Rheinstrasse 13, 26506 Norden
> > GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
