[Qgis-developer] dep trouble with feisty packages
Tim Sutton
tim at linfiniti.com
Wed Oct 17 06:22:29 EDT 2007
Hi
Actually it should install without backports (but as mentioned python
may present you issues). I'll tweak the packages and make a new set
available if you would be so kind as to test again.
Regards
Tim
2007/10/17, icosa atropa <icos.atropa at gmail.com>:
> Thanks, I'll give it a try when i have a chance.
> I was wondering if a little more information could be added to the
> README.txt @ http://qgis.org/uploadfiles/testbuilds/? Knowing what to
> expect, i.e. requirements, would be nice.
> -xian
> On 10/16/07, Matthew Perry <perrygeo at gmail.com> wrote:
> > On 10/16/07, icosa atropa <icos.atropa at gmail.com> wrote:
> > > Tim,
> > > I tried installing feisty packages from
> > > http://qgis.org/uploadfiles/testbuilds/, but I'm still getting
> > > problems with deps.
> > > I first did a fresh apt-get update/upgrade/dist-upgrade prior to
> > > installing debs. Still, I get stuck on libqgis1 with the following:
> > > xian at wrp:/usr/local/src$ sudo dpkg -i libqgis1_0.9.0_i386.deb
> > > Selecting previously deselected package libqgis1.
> > > (Reading database ... 71051 files and directories currently installed.)
> > > Unpacking libqgis1 (from libqgis1_0.9.0_i386.deb) ...
> > > dpkg: dependency problems prevent configuration of libqgis1:
> > > libqgis1 depends on libqt4-core (>= 4.3.0); however:
> > > Version of libqt4-core on system is 4.2.3-0ubuntu3.
> > Try adding the backports repository which should have qt4.3 :
> > deb http://us.archive.ubuntu.com/ubuntu/ feisty-backports main
> > restricted universe multiverse
> > Keep in mind that the recent pyqt-dev-tools (pyuic, etc) have not been
> > backported to feisty so if you're planning on doing any gui
> > development work with python and qt, you'll have to tread carefully.
> > - matt
> > > libqgis1 depends on libqt4-gui (>= 4.3.0); however:
> > > Version of libqt4-gui on system is 4.2.3-0ubuntu3.
> > > libqgis1 depends on libqt4-qt3support (>= 4.3.0); however:
> > > Version of libqt4-qt3support on system is 4.2.3-0ubuntu3.
> > > dpkg: error processing libqgis1 (--install):
> > > dependency problems - leaving unconfigured
> > > Errors were encountered while processing:
> > > libqgis1
> > Matthew T. Perry
> > http://www.perrygeo.net
> > "Never ascribe to malice, that which can be adequately explained by
> > incompetence."
> Far better an approximate answer to the right question, which is often
> vague, than the exact answer to the wrong question, which can always
> be made precise -- j.w. tukey
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
