[Qgis-developer] GDAL Python Bindings
Christopher Barker Chris.Barker at noaa.gov
Wed Oct 31 12:27:26 EDT 2007
Hi folks,
Sorry for the cross-post, but it seemed topical to both qgis and gdal.
Martin Dobias wrote:
 >> GDAL already uses swig ngpython bindings, can't you reuse those ? There
 >> is a gdalconst.py generated by swig which contains the enums.
 > I don't think this would be a good idea. First, we would introduce
 > dependency on GDAL python bindings.
Well, there is a dependency on GDAL already, so why not the bindings?
I really think it is better for the GDAL user community as a whole to
work to improve one set of bindings for GDAL, rather than have multiple
sets.
 > Second, and more importantly,
 > there seems to be a technical barrier - I have no idea how to connect
 > SIP and SWIG bindings.
What are the barriers exactly? I now nothing of SIP, and a little about
SWIG. However, I think the key is to use Python as the intermediary, and
not try to have SIP types dealing directly with GDAL C stuff. To do this
efficiently, there may be a need to add a thing or two to the GDAL SWIG
bindings and the Qgis bindings.
In particular, thinking about a raster band, it could be a pretty good
sized bock of data, so we'd want a way to get a GDAL raster band into
whatever type you need for QGIS without a whole lot of data copying. By
default, we might end up with:
gdal generates a raster band. (first copy)
it is converted to a Python string (two copies)
it is converted to a QGIS raster band equivelent (three copies)
It would be nice to just allocate the memory in GDAl, and pass that
pointer through to whatever the QGIS type is. The way to do that is to
use the Python buffer protocol, or even better the new nd-array protocol
introduced by numpy, and slated for inclusion in future pythons:
http://numpy.scipy.org/array_interface.shtml
http://www.python.org/dev/peps/pep-3118/
I'm hoping to add this support to the GDAL bindings anyway, for
efficient transfer to/from numpy arrays.
By the way, does pyQt and/or Qgis support numpy arrays at all now?
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
