[Qgis-developer] Postgresql layers not displaying?
icosa atropa icos.atropa at gmail.com
Tue Sep 25 08:42:43 EDT 2007
I just rebuilt from source on Ubuntu feisty following directions at
http://wiki.qgis.org/qgiswiki/BuildingFromSource.
New build runs fine - i connect to WMS layers, add and display vectors fine.
Problem comes in displaying Postgis layers.  The layers add just fine,
and I can even zoom to the layer extent and pull up the data table.
The layer just won't render, no matter what i do.
In the invoking terminal, I get the following messages, the first set
when I select the layer for display (from the legend), and the second
set when i unselect it:
Warning: Object::disconnect: No such signal QgsRasterLayer::selectionChanged()
Warning: Object::connect: No such signal QgsRasterLayer::selectionChanged()
QgsComposerMap::canvasChanged
QgsComposerMapt::paint mPlotStyle = 0 mPreviewMode = 0
use cache
QgsComposerMap::cache()
extent = 3.23401 x 1.96161
cache = 304 x 184
transform = Map units/pixel: 0.0106382 X minimum: -108.281 Y minimum:
33.6586 Y maximum: 184
Warning: http://wms.jpl.nasa.gov/wms.cgi?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=-108.280781,33.658623,-105.046771,35.616050&SRS=EPSG:4326&WIDTH=304&HEIGHT=185&LAYERS=us_ned&STYLES=real&FORMAT=image/jpeg
scale = 0.802632
p&BBOX=-86.239659,47.191708,-84.892416,48.393197&SRS=EPSG:4326&WIDTH=684&HEIGHT=
610&LAYERS=us_ned&STYLES=real&FORMAT=image/jpeg
use cache
cache = 304 x 184
transform = Map units/pixel: 0.0106382 X minimum: -108.281 Y minimum: 33.6586 Y
maximum: 184
scale = 0.802632
Warning: QPaintEngine::setSystemClip: Should not be changed while engine is acti
ve
ve
Warning: QPaintEngine::setSystemRect: Should not be changed while engine is acti
ve
ve
ve
[_lots_ of these follow ]
Any thoughts?
thanks!
christian
