[Qgis-developer] Compiling QGIS 0.9 using Microsoft Express 2005
Tim Sutton tim at linfiniti.com
Wed Sep 26 15:43:55 EDT 2007
Hi All (and especially David and Martin!)
I've been trying to build QGIS on a clean xp mage in parallels. After
too many hassles to mention I have all the deps built or downloaded
and installed. Im following the notes David previously sent to the
list and notes from Mateusz on building Qt with msvc as well as just
groping along in the dark a lot :-)
Trying to compile qgis core I get 332 errors which I must say is some
kind of personal record ;-) Most seem to deal with geos namespace
issues. Do you have any hints on how to resolve that?
Also (for Martin) the search stuff doesnt seem to be compiling (flex / bison).
I would really appreciate any hints on resolving these issues! Full
transcript from msvc express below...
Regards
Tim
Build Log      Rebuild started: Project: qgis_core, Configuration: Debug|Win32
 Command Lines      Creating temporary file
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008434282052.bat"
with contents
@echo off
C:\Qt\4.3.1\bin\moc.exe -I C:/Qt/4.3.1/include -I
C:/Qt/4.3.1/include/Qt3Support -I C:/Qt/4.3.1/include/QtSvg -I
C:/Qt/4.3.1/include/QtGui -I C:/Qt/4.3.1/include/QtXml -I
C:/Qt/4.3.1/include/QtNetwork -I C:/Qt/4.3.1/include/QtCore -I
C:/dev/cpp/qgis/build -o
C:/dev/cpp/qgis/build/src/core/moc_qgsrasterviewport.cxx
C:/dev/cpp/qgis/src/core/raster/qgsrasterviewport.h
if errorlevel 1 goto VCReportError
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from
"Generating moc_qgsrasterviewport.cxx"
exit 1
:VCEnd
Creating command line
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008534282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsrasterlayer.cxx
C:/dev/cpp/qgis/src/core/raster/qgsrasterlayer.h
goto VCEnd
:VCReportError
"Generating moc_qgsrasterlayer.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008634282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsvectorlayer.cxx
C:/dev/cpp/qgis/src/core/qgsvectorlayer.h
goto VCEnd
:VCReportError
"Generating moc_qgsvectorlayer.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008734282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsrunprocess.cxx
C:/dev/cpp/qgis/src/core/qgsrunprocess.h
goto VCEnd
:VCReportError
"Generating moc_qgsrunprocess.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008834282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsrasterdataprovider.cxx
C:/dev/cpp/qgis/src/core/qgsrasterdataprovider.h
goto VCEnd
:VCReportError
"Generating moc_qgsrasterdataprovider.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008934282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsproject.cxx
C:/dev/cpp/qgis/src/core/qgsproject.h
goto VCEnd
:VCReportError
"Generating moc_qgsproject.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008A34282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsmessageoutput.cxx
C:/dev/cpp/qgis/src/core/qgsmessageoutput.h
goto VCEnd
:VCReportError
"Generating moc_qgsmessageoutput.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008B34282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsmaprender.cxx
C:/dev/cpp/qgis/src/core/qgsmaprender.h
goto VCEnd
:VCReportError
"Generating moc_qgsmaprender.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008C34282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsmaplayerregistry.cxx
C:/dev/cpp/qgis/src/core/qgsmaplayerregistry.h
goto VCEnd
:VCReportError
"Generating moc_qgsmaplayerregistry.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008D34282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsmaplayer.cxx
C:/dev/cpp/qgis/src/core/qgsmaplayer.h
goto VCEnd
:VCReportError
"Generating moc_qgsmaplayer.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008E34282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgshttptransaction.cxx
C:/dev/cpp/qgis/src/core/qgshttptransaction.h
goto VCEnd
:VCReportError
"Generating moc_qgshttptransaction.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00008F34282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgsdataprovider.cxx
C:/dev/cpp/qgis/src/core/qgsdataprovider.h
goto VCEnd
:VCReportError
"Generating moc_qgsdataprovider.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00009034282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgscoordinatetransform.cxx
C:/dev/cpp/qgis/src/core/qgscoordinatetransform.h
goto VCEnd
:VCReportError
"Generating moc_qgscoordinatetransform.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00009134282052.bat"
with contents
@echo off
C:/dev/cpp/qgis/build/src/core/moc_qgscontexthelp.cxx
C:/dev/cpp/qgis/src/core/qgscontexthelp.h
goto VCEnd
:VCReportError
"Generating moc_qgscontexthelp.cxx"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00009234282052.bat"
with contents
@echo off
C:\dev\cpp\bison\bin\bison.exe
-oC:/dev/cpp/qgis/build/src/core/qgssearchstringparser.cpp -d -v -t
C:/dev/cpp/qgis/src/core/qgssearchstringparser.yy
goto VCEnd
:VCReportError
"Generating qgssearchstringparser.cpp"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00009334282052.bat"
with contents
@echo off
C:\dev\cpp\flex\bin\flex.exe
-oC:/dev/cpp/qgis/build/src/core/flex_qgssearchstringlexer.cpp -d
C:/dev/cpp/qgis/src/core/qgssearchstringlexer.ll
goto VCEnd
:VCReportError
"Generating flex_qgssearchstringlexer.cpp"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BAT00009434282052.bat"
with contents
@echo off
"C:\Program Files\CMake 2.4\bin\cmake.exe" -HC:/dev/cpp/qgis
-BC:/dev/cpp/qgis/build
goto VCEnd
:VCReportError
"Building Custom Rule C:/dev/cpp/qgis/src/core/CMakeLists.txt"
exit 1
:VCEnd
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\RSP00009534282052.rsp"
with contents
/Od /I "C:\Qt\4.3.1\include" /I "C:\Qt\4.3.1\include\Qt3Support" /I
"C:\Qt\4.3.1\include\QtSvg" /I "C:\Qt\4.3.1\include\QtGui" /I
"C:\Qt\4.3.1\include\QtXml" /I "C:\Qt\4.3.1\include\QtNetwork" /I
"C:\Qt\4.3.1\include\QtCore" /I "C:\dev\cpp\qgis\build" /I
"C:\dev\cpp\qgis\src\core" /I "C:\dev\cpp\qgis\src\core\raster" /I
"C:\dev\cpp\qgis\src\core\renderer" /I
"C:\dev\cpp\qgis\src\core\symbology" /I
"C:\dev\cpp\qgis\src\core\spatialindex\include" /I
"C:\dev\cpp\proj-4.5.0\src" /I "C:\dev\cpp\sqlite3" /I
"C:\dev\cpp\geos-2.2.1\source\headers" /I "C:\dev\cpp\gdal\gcore" /I
"C:\dev\cpp\gdal\port" /I "C:\dev\cpp\gdal\ogr" /I
"C:\dev\cpp\gdal\alg" /D "WIN32" /D "_WINDOWS" /D "_DEBUG" /D
"QT_SHARED" /D "QT_3SUPPORT_LIB" /D "QT3_SUPPORT" /D "QT_SVG_LIB" /D
"QT_GUI_LIB" /D "QT_XML_LIB" /D "QT_NETWORK_LIB" /D "QT_CORE_LIB" /D
"CORE_EXPORT=__declspec(dllimport)" /D
"GUI_EXPORT=__declspec(dllimport)" /D
"CORE_EXPORT=__declspec(dllexport)" /D "CMAKE_INTDIR=\"Debug\"" /D
"qgis_core_EXPORTS" /D "_WINDLL" /D "_MBCS" /FD /EHsc /RTC1 /MDd
/Fo"qgis_core.dir\Debug\\"
/Fd"C:/dev/cpp/qgis/build/src/core/Debug/qgis_core.pdb" /W3 /c /Zi /TP
  /Zm1000
..\..\..\src\core\spatialindex\rtree\Statistics.cc
..\..\..\src\core\spatialindex\rtree\RTree.cc
..\..\..\src\core\spatialindex\rtree\Node.cc
..\..\..\src\core\spatialindex\rtree\Leaf.cc
..\..\..\src\core\spatialindex\rtree\Index.cc
..\..\..\src\core\spatialindex\rtree\BulkLoader.cc
..\..\..\src\core\spatialindex\storagemanager\RandomEvictionsBuffer.cc
..\..\..\src\core\spatialindex\storagemanager\MemoryStorageManager.cc
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc
..\..\..\src\core\spatialindex\storagemanager\Buffer.cc
..\..\..\src\core\spatialindex\spatialindex\SpatialIndexImpl.cc
..\..\..\src\core\spatialindex\geometry\Region.cc
..\..\..\src\core\spatialindex\geometry\Point.cc
..\..\..\src\core\spatialindex\geometry\LineSegment.cc
..\..\..\src\core\spatialindex\tools\Tools.cc
..\..\..\src\core\spatialindex\tools\TemporaryFile.cc
..\..\..\src\core\spatialindex\tools\ExternalSort.cc
.\moc_qgsrasterviewport.cxx
.\moc_qgsrasterlayer.cxx
.\moc_qgsvectorlayer.cxx
.\moc_qgsrunprocess.cxx
.\moc_qgsrasterdataprovider.cxx
.\moc_qgsproject.cxx
.\moc_qgsmessageoutput.cxx
.\moc_qgsmaprender.cxx
.\moc_qgsmaplayerregistry.cxx
.\moc_qgsmaplayer.cxx
.\moc_qgshttptransaction.cxx
.\moc_qgsdataprovider.cxx
.\moc_qgscoordinatetransform.cxx
.\moc_qgscontexthelp.cxx
.\qgssearchstringparser.cpp
..\..\..\src\core\spatialindex\qgsspatialindex.cpp
..\..\..\src\core\symbology\qgssymbologyutils.cpp
..\..\..\src\core\symbology\qgssymbol.cpp
..\..\..\src\core\symbology\qgsmarkercatalogue.cpp
..\..\..\src\core\renderer\qgsuniquevaluerenderer.cpp
..\..\..\src\core\renderer\qgssinglesymbolrenderer.cpp
..\..\..\src\core\renderer\qgsrenderer.cpp
..\..\..\src\core\renderer\qgsgraduatedsymbolrenderer.cpp
..\..\..\src\core\renderer\qgscontinuouscolorrenderer.cpp
..\..\..\src\core\raster\qgsrasterlayer.cpp
..\..\..\src\core\raster\qgscolortable.cpp
..\..\..\src\core\qgsvectorlayer.cpp
..\..\..\src\core\qgsvectorfilewriter.cpp
..\..\..\src\core\qgsvectordataprovider.cpp
..\..\..\src\core\qgsspatialrefsys.cpp
..\..\..\src\core\qgssearchtreenode.cpp
..\..\..\src\core\qgssearchstring.cpp
..\..\..\src\core\qgsscalecalculator.cpp
..\..\..\src\core\qgsrunprocess.cpp
..\..\..\src\core\qgsrect.cpp
..\..\..\src\core\qgsrasterdataprovider.cpp
..\..\..\src\core\qgsproviderregistry.cpp
..\..\..\src\core\qgsprovidermetadata.cpp
..\..\..\src\core\qgsproviderextentcalcevent.cpp
..\..\..\src\core\qgsprovidercountcalcevent.cpp
..\..\..\src\core\qgsprojectproperty.cpp
..\..\..\src\core\qgsproject.cpp
..\..\..\src\core\qgspoint.cpp
..\..\..\src\core\qgsmessageoutput.cpp
..\..\..\src\core\qgsmaptopixel.cpp
..\..\..\src\core\qgsmaprender.cpp
..\..\..\src\core\qgsmaplayerregistry.cpp
..\..\..\src\core\qgsmaplayer.cpp
..\..\..\src\core\qgslogger.cpp
..\..\..\src\core\qgsline.cpp
..\..\..\src\core\qgslabelattributes.cpp
..\..\..\src\core\qgslabel.cpp
..\..\..\src\core\qgshttptransaction.cpp
..\..\..\src\core\qgsgeometryvertexindex.cpp
..\..\..\src\core\qgsgeometry.cpp
..\..\..\src\core\qgsfield.cpp
..\..\..\src\core\qgsfeature.cpp
..\..\..\src\core\qgsexception.cpp
..\..\..\src\core\qgsdistancearea.cpp
..\..\..\src\core\qgsdatasourceuri.cpp
..\..\..\src\core\qgscoordinatetransform.cpp
..\..\..\src\core\qgscontexthelp.cpp
..\..\..\src\core\qgsclipper.cpp
..\..\..\src\core\qgsattributeaction.cpp
..\..\..\src\core\qgsapplication.cpp
..\..\..\src\core\qgis.cpp
Creating command line "cl.exe
@c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\RSP00009534282052.rsp
/nologo /errorReport:prompt"
"c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\RSP00009634282052.rsp"
with contents
 -w  /Zm1000
.\flex_qgssearchstringlexer.cpp
@c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\RSP00009634282052.rsp
 Output Window      Generating moc_qgsrasterviewport.cxx
C:/dev/cpp/qgis/src/core/raster/qgsrasterviewport.h(0): Warning: No
relevant classes found. No output generated.
-- Found Proj: C:/dev/cpp/proj-4.5.0/src/proj.lib
-- Found Sqlite3: C:/dev/cpp/sqlite3/sqlite3.lib
-- Found GEOS: C:/dev/cpp/geos-2.2.1/source/geos.lib
-- Found GDAL: C:/dev/cpp/gdal/gdal.lib
-- Could not find PostgreSQL
-- Found Expat: C:/dev/cpp/Expat 2.0.1/Bin/libexpat.lib
-- Using GSL from C:/dev/cpp/gsl
-- Could not find GRASS
-- Found Qt-Version 4.3.1
-- Configuring done
-- Generating done
-- Build files have been written to: C:/dev/cpp/qgis/build
Compiling...
Statistics.cc
c:\dev\cpp\qgis\src\core\spatialindex\include\Tools.h(405) : error
C2039: '<<' : is not a member of 'Tools'
c:\dev\cpp\qgis\src\core\spatialindex\include\Tools.h(612) : error
C2063: 'Tools::operator <<' : not a function
C:\dev\cpp\qgis\src\core\spatialindex\include\SpatialIndex.h(186) :
error C2371: 'in' : redefinition; different basic types
: see declaration of 'in'
c:\dev\cpp\qgis\src\core\spatialindex\include\RTree.h(73) : error
RTree.cc
c:\dev\cpp\qgis\src\core\spatialindex\rtree\BulkLoader.h(41) : warning
C4290: C++ exception specification ignored except to indicate a
function is not __declspec(nothrow)
c:\dev\cpp\qgis\src\core\spatialindex\rtree\BulkLoader.h(42) : warning
c:\dev\cpp\qgis\src\core\spatialindex\rtree\BulkLoader.h(82) : warning
..\..\..\src\core\spatialindex\rtree\RTree.cc(136) : error C2244:
'returnRTree' : unable to match function definition to an existing
declaration
        ..\..\..\src\core\spatialindex\rtree\RTree.cc(135) : see
declaration of 'returnRTree'
..\..\..\src\core\spatialindex\rtree\RTree.cc(136) : fatal error
C1903: unable to recover from previous error(s); stopping compilation
Node.cc
..\..\..\src\core\spatialindex\rtree\Node.cc(220) : error C2872:
'RTree' : ambiguous symbol
        could be
'c:\dev\cpp\qgis\src\core\spatialindex\rtree\RTree.h(33) :
SpatialIndex::RTree::RTree'
        or 'SpatialIndex::RTree'
Leaf.cc
..\..\..\src\core\spatialindex\rtree\Leaf.cc(38) : error C2872:
        could be
Index.cc
..\..\..\src\core\spatialindex\rtree\Index.cc(38) : error C2872:
        could be
BulkLoader.cc
..\..\..\src\core\spatialindex\rtree\BulkLoader.cc(68) : warning
..\..\..\src\core\spatialindex\rtree\BulkLoader.cc(73) : warning
..\..\..\src\core\spatialindex\rtree\BulkLoader.cc(198) : warning
..\..\..\src\core\spatialindex\rtree\BulkLoader.cc(227) : error C2872:
        could be
..\..\..\src\core\spatialindex\rtree\BulkLoader.cc(280) : error C2872:
        could be
..\..\..\src\core\spatialindex\rtree\BulkLoader.cc(343) : error C2872:
        could be
..\..\..\src\core\spatialindex\storagemanager\RandomEvictionsBuffer.cc(43)
: error C2244: 'returnRandomEvictionsBuffer' : unable to match
function definition to an existing declaration
        ..\..\..\src\core\spatialindex\storagemanager\RandomEvictionsBuffer.cc(42)
: see declaration of 'returnRandomEvictionsBuffer'
: fatal error C1903: unable to recover from previous error(s);
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(117)
: error C2065: 'F_OK' : undeclared identifier
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(126)
: error C2065: 'R_OK' : undeclared identifier
: error C2065: 'W_OK' : undeclared identifier
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(181)
: error C2065: 'ssize_t' : undeclared identifier
: error C2146: syntax error : missing ';' before identifier
'bytesread'
: error C2065: 'bytesread' : undeclared identifier
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(196)
'bytesread'
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(256)
'byteswritten'
: error C2065: 'byteswritten' : undeclared identifier
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(335)
'bytesread'
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(377)
'byteswritten'
..\..\..\src\core\spatialindex\storagemanager\DiskStorageManager.cc(430)
'byteswritten'
Buffer.cc
SpatialIndexImpl.cc
Region.cc
C:\dev\cpp\qgis\src\core\spatialindex\include\Tools.h(405) : error
C:\dev\cpp\qgis\src\core\spatialindex\include\Tools.h(612) : error
..\..\..\src\core\spatialindex\geometry\Region.cc(107) : error C2039:
'numeric_limits' : is not a member of 'std'
..\..\..\src\core\spatialindex\geometry\Region.cc(107) : error C2065:
'numeric_limits' : undeclared identifier
..\..\..\src\core\spatialindex\geometry\Region.cc(107) : error C2062:
type 'double' unexpected
'epsilon' : is not a member of '`global namespace''
..\..\..\src\core\spatialindex\geometry\Region.cc(108) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(109) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(110) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(283) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(283) : error C2062:
..\..\..\src\core\spatialindex\geometry\Region.cc(284) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(285) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(286) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(344) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(344) : error C2062:
..\..\..\src\core\spatialindex\geometry\Region.cc(345) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(346) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(347) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(502) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(502) : error C2062:
'max' : is not a member of '`global namespace''
..\..\..\src\core\spatialindex\geometry\Region.cc(503) : error C2039:
..\..\..\src\core\spatialindex\geometry\Region.cc(503) : error C2062:
Point.cc
..\..\..\src\core\spatialindex\geometry\Point.cc(73) : error C2039:
..\..\..\src\core\spatialindex\geometry\Point.cc(73) : error C2065:
..\..\..\src\core\spatialindex\geometry\Point.cc(73) : error C2062:
..\..\..\src\core\spatialindex\geometry\Point.cc(74) : error C2039:
..\..\..\src\core\spatialindex\geometry\Point.cc(229) : error C2039:
..\..\..\src\core\spatialindex\geometry\Point.cc(229) : error C2062:
LineSegment.cc
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(95) : error
C2039: 'numeric_limits' : is not a member of 'std'
C2065: 'numeric_limits' : undeclared identifier
C2062: type 'double' unexpected
C2039: 'epsilon' : is not a member of '`global namespace''
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(96) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(99) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(100) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(173) : error
C2057: expected constant expression
C2466: cannot allocate an array of constant size 0
C2133: 'coords' : unknown size
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(192) : error
C2133: 'low' : unknown size
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(193) : error
C2133: 'high' : unknown size
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(242) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(243) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(245) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(246) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(271) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(272) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(273) : error
C2143: syntax error : missing ';' before '{'
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(278) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(279) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(280) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(336) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(337) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(339) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(340) : error
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(350) : error
C2039: 'max' : is not a member of '`global namespace''
..\..\..\src\core\spatialindex\geometry\LineSegment.cc(351) : error
Tools.cc
..\..\..\src\core\spatialindex\tools\Tools.cc(208) : warning C4800:
'byte' : forcing value to bool 'true' or 'false' (performance warning)
..\..\..\src\core\spatialindex\tools\Tools.cc(440) : error C2039:
..\..\..\src\core\spatialindex\tools\Tools.cc(440) : error C2065:
..\..\..\src\core\spatialindex\tools\Tools.cc(440) : error C2062: type
'double' unexpected
..\..\..\src\core\spatialindex\tools\Tools.cc(441) : error C2039:
..\..\..\src\core\spatialindex\tools\Tools.cc(442) : error C2039:
..\..\..\src\core\spatialindex\tools\Tools.cc(443) : error C2039:
..\..\..\src\core\spatialindex\tools\Tools.cc(582) : error C2057:
..\..\..\src\core\spatialindex\tools\Tools.cc(582) : error C2466:
..\..\..\src\core\spatialindex\tools\Tools.cc(582) : error C2133: 'cv'
: unknown size
..\..\..\src\core\spatialindex\tools\Tools.cc(582) : error C2133: 'pv'
: unknown size
..\..\..\src\core\spatialindex\tools\Tools.cc(982) : error C2039:
'tolower' : is not a member of 'std'
..\..\..\src\core\spatialindex\tools\Tools.cc(987) : error C2039:
'toupper' : is not a member of 'std'
..\..\..\src\core\spatialindex\tools\Tools.cc(1105) : error C2248:
'Tools::UniversalHash::m_k' : cannot access private member declared in
class 'Tools::UniversalHash'
        C:\dev\cpp\qgis\src\core\spatialindex\include\Tools.h(607) :
see declaration of 'Tools::UniversalHash::m_k'
        C:\dev\cpp\qgis\src\core\spatialindex\include\Tools.h(575) :
see declaration of 'Tools::UniversalHash'
..\..\..\src\core\spatialindex\tools\Tools.cc(1107) : error C2248:
..\..\..\src\core\spatialindex\tools\Tools.cc(1108) : error C2248:
'Tools::UniversalHash::m_a' : cannot access private member declared in
        C:\dev\cpp\qgis\src\core\spatialindex\include\Tools.h(606) :
see declaration of 'Tools::UniversalHash::m_a'
TemporaryFile.cc
ExternalSort.cc
Generating Code...
Compiling...
moc_qgsproject.cxx
moc_qgsmaplayer.cxx
c1xx : fatal error C1083: Cannot open source file:
'.\qgssearchstringparser.cpp': No such file or directory
qgsspatialindex.cpp
C:\dev\cpp\qgis\src\core\qgsgeometry.h(137) : error C3083: 'geom': the
symbol to the left of a '::' must be a type
C:\dev\cpp\qgis\src\core\qgsgeometry.h(311) : error C3083: 'geom': the
C:\dev\cpp\qgis\src\core\qgsgeometry.h(354) : error C3083: 'geom': the
C:\dev\cpp\qgis\src\core\qgsgeometry.h(355) : error C3083: 'geom': the
qgssymbol.cpp
qgsrenderer.cpp
Generating Code...
Compiling...
qgsrasterlayer.cpp
..\..\..\src\core\raster\qgsrasterlayer.cpp(62) : warning C4067:
unexpected tokens following preprocessor directive - expected a
newline
..\..\..\src\core\raster\qgsrasterlayer.cpp(4400) : warning C4996:
'sscanf' was declared deprecated
        C:\Program Files\Microsoft Visual Studio
8\VC\include\stdio.h(311) : see declaration of 'sscanf'
        Message: 'This function or variable may be unsafe. Consider
using sscanf_s instead. To disable deprecation, use
_CRT_SECURE_NO_DEPRECATE. See online help for details.'
qgscolortable.cpp
c:\dev\cpp\qgis\src\core\raster\qgscolortable.h(106) : warning C4251:
'QgsColorTable::mDiscrete' : class 'std::vector<_Ty>' needs to have
dll-interface to be used by clients of class 'QgsColorTable'
        with
            _Ty=DISCRETE
c:\dev\cpp\qgis\src\core\raster\qgscolortable.h(109) : warning C4251:
'QgsColorTable::mRamp' : class 'std::vector<_Ty>' needs to have
        with
            _Ty=RAMP
qgsvectorlayer.cpp
c:\dev\cpp\qgis\src\core\qgsgeometry.h(137) : error C3083: 'geom': the
c:\dev\cpp\qgis\src\core\qgsgeometry.h(311) : error C3083: 'geom': the
c:\dev\cpp\qgis\src\core\qgsgeometry.h(354) : error C3083: 'geom': the
c:\dev\cpp\qgis\src\core\qgsgeometry.h(355) : error C3083: 'geom': the
..\..\..\src\core\qgsvectorfilewriter.cpp(33) : fatal error C1083:
Cannot open include file: 'ogrsf_frmts.h': No such file or directory
qgssearchstring.cpp
qgsrunprocess.cpp
qgsrect.cpp
qgsproject.cpp
qgspoint.cpp
Generating Code...
Compiling...
qgsmaptopixel.cpp
qgsmaprender.cpp
..\..\..\src\core\qgsmaprender.cpp(455) : warning C4101: 'cse' :
unreferenced local variable
qgsmaplayer.cpp
qgslogger.cpp
..\..\..\src\core\qgslogger.cpp(138) : warning C4996: 'getenv' was
declared deprecated
8\VC\include\stdlib.h(483) : see declaration of 'getenv'
using _dupenv_s instead. To disable deprecation, use
..\..\..\src\core\qgslogger.cpp(159) : warning C4996: 'getenv' was
declared deprecated
qgsline.cpp
qgslabel.cpp
c:\dev\cpp\qgis\src\core\qgsgeometryvertexindex.h(80) : warning C4251:
'QgsGeometryVertexIndex::mIndex' : class 'std::vector<_Ty>' needs to
have dll-interface to be used by clients of class
'QgsGeometryVertexIndex'
        with
            _Ty=int
qgsgeometry.cpp
..\..\..\src\core\qgsgeometry.cpp(29) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(62) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(64) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(67) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(68) : warning C4018: '<' :
signed/unsigned mismatch
..\..\..\src\core\qgsgeometry.cpp(70) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(88) : error C3083: 'io': the symbol
..\..\..\src\core\qgsgeometry.cpp(89) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(97) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(98) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(106) : error C3083: 'geom': the
'CoordinateArraySequenceFactory': the symbol to the left of a '::'
must be a type
..\..\..\src\core\qgsgeometry.cpp(106) : error C2039: 'instance' : is
not a member of 'geos'
..\..\..\src\core\qgsgeometry.cpp(106) : error C3861: 'instance':
identifier not found
..\..\..\src\core\qgsgeometry.cpp(107) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(113) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(117) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(123) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(128) : error C3083: 'geom': the
must be a type
..\..\..\src\core\qgsgeometry.cpp(128) : error C2039: 'instance' : is
..\..\..\src\core\qgsgeometry.cpp(128) : error C3861: 'instance':
..\..\..\src\core\qgsgeometry.cpp(130) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(135) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(140) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(143) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(156) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(159) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(166) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(207) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(209) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(212) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(213) : warning C4018: '<' :
..\..\..\src\core\qgsgeometry.cpp(215) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(343) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(871) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(872) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(885) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(893) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(903) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(1792) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(1795) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2034) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2037) : warning C4018: '<' :
..\..\..\src\core\qgsgeometry.cpp(2306) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2307) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2308) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2312) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2321) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2329) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2334) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2337) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2341) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2342) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2345) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2354) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2355) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2359) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2363) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2368) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2370) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2380) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2402) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2415) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2433) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2442) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2452) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2485) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2494) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2497) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2500) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2502) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2503) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2513) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2514) : warning C4018: '<' :
..\..\..\src\core\qgsgeometry.cpp(2516) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2522) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2532) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(2845) : error C3083: 'util': the
..\..\..\src\core\qgsgeometry.cpp(2850) : error C2039: 'what' : is not
a member of 'geos::TopologyException'
        C:\dev\cpp\geos-2.2.1\source\headers\geos/util.h(88) : see
declaration of 'geos::TopologyException'
..\..\..\src\core\qgsgeometry.cpp(2869) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(3207) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(3216) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(3231) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(3244) : error C3083: 'geom': the
..\..\..\src\core\qgsgeometry.cpp(3244) : fatal error C1003: error
count exceeds 100; stopping compilation
qgsfield.cpp
qgsfeature.cpp
qgsexception.cpp
qgsdistancearea.cpp
qgscontexthelp.cpp
qgsclipper.cpp
Generating Code...
Compiling...
qgsapplication.cpp
qgis.cpp
Generating Code...
 Results      Build log was saved at
"file://c:\dev\cpp\qgis\build\src\core\qgis_core.dir\Debug\BuildLog.htm"
qgis_core - 332 error(s), 22 warning(s)
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
