[Qgis-developer] Compiling QGIS 0.9 using Microsoft Express 2005
Tim Sutton tim at linfiniti.com
Wed Sep 26 20:54:43 EDT 2007
Hi David
Ah thanks I thought the patch was applied already. Ok Ill apply it
tomorrow when Im at work and try to resolve the issue Martin mentioned
and then commit it once they are resolved. I wonder if you could
regenerat your path against current trunk to minimise any conflicts I
may run into?
Many thanks
Tim
2007/9/26, lists at dwillis.gotadsl.co.uk <lists at dwillis.gotadsl.co.uk>:
> > Ok in follow up to the previos message I discoered I must have copied
> > in the incorrect version.h into geos....I tweaked that file and all
> > the geos errors are gone leaving me with (only!) 206 others....
> It looks suspiciously like you need to apply my patch I sent to the list a wee
> bit back. I've attached another copy to this message. I've not tried building
> from svn for a while but I'm working on the assumption that nothing has
> changed in the spatial index code since I generated this patch... Give it a
> try and let me know how you get on.
> David
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
