[Qgis-developer] Compiling QGIS 0.9 using Microsoft Express 2005
Tim Sutton tim at linfiniti.com
Wed Sep 26 20:55:45 EDT 2007
Hi Martin
Thanks for the tips - Ill check tomorrow to see what files are being
generated and what arent. By the way should I be using flex of flex++?
Regards
Tim
2007/9/26, Martin Dobias <wonder.sk at gmail.com>:
> Hi Tim,
> maybe you have something wrong with path to flex and bison - the lexer
> and parser .cpp files have been created or not? (or check whether
> you're not missing some DLLs in PATH they need)
> I've been able to build and run QGIS with David's patch some time ago,
> but I didn't apply it so far to SVN as some things happened to be
> still unresolved (and I didn't have time to investigate it further):
> - I had problems to apply the patch on linux due some mismatch of
> windows and linux line endings
> - I couldn't compile QGIS with MinGW with this patch (some problems
> with QgsApplication)
> But I think we really should sort out the things and make possible to
> build QGIS with MSVC without troubles - since next Qt open source
> versions will support it too.
> Regards
> Martin
> On 9/26/07, Tim Sutton <tim at linfiniti.com> wrote:
> > Hi All
> > Ok in follow up to the previos message I discoered I must have copied
> > in the incorrect version.h into geos....I tweaked that file and all
> > the geos errors are gone leaving me with (only!) 206 others....
> > Regards
> > Tim
> > 2007/9/26, Tim Sutton <tim at linfiniti.com>:
> > > Hi All (and especially David and Martin!)
> > > I've been trying to build QGIS on a clean xp mage in parallels. After
> > > too many hassles to mention I have all the deps built or downloaded
> > > and installed. Im following the notes David previously sent to the
> > > list and notes from Mateusz on building Qt with msvc as well as just
> > > groping along in the dark a lot :-)
> > > Trying to compile qgis core I get 332 errors which I must say is some
> > > kind of personal record ;-) Most seem to deal with geos namespace
> > > issues. Do you have any hints on how to resolve that?
> > > Also (for Martin) the search stuff doesnt seem to be compiling (flex / bison).
> > > I would really appreciate any hints on resolving these issues! Full
> > > transcript from msvc express below...
> > > Regards
> > > Tim
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
