AW: [Qgis-developer] Planning for QGIS 1.0.0 '????'
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Fri Aug 1 03:10:18 EDT 2008
Hi Jürgen and Tim,
I'm going to look at it next monday when I'm back from holidays.
Yes, this function is in use for polygon splitting. However, I don't remember how important the call for cutEdges function really is. It is possible that this section aborts polygon splits where the splitting line doesn't go through the whole polygon.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: Tim Sutton [mailto:tim at linfiniti.com]
Gesendet: Do 31.07.2008 23:07
An: Jürgen E. Fischer; Hugentobler  Marco
Cc: qgis-developer at lists.osgeo.org
Betreff: Re: [Qgis-developer] Planning for QGIS 1.0.0 '????'
Hi
> The GEOS patch only adds a C-API call to get the cut edges from the GEOS
> polygonizer.  Which is only used for splitting polygons for
> QgsMapToolSplitFeatures (see src/core/qgsgeometry.cpp:4689 [2]).
> I must admit, that I'm not really sure if it's just a sanity check,
> which we might - at least temporary - disable.  Or disable (again
> temporarily) the whole split feature feature.
I think we would cause a riot if we disable split feature. Marco is
that your tool (split feature) - is there any way we can use a geos
c-api call there? Would be good to do so and get Jefs changes into
trunk then.
Regards
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
Blog: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
