[Qgis-developer] [SoC] beta release of Home Range plugin for QGIS
Anne Ghisla
a.ghisla at studenti.uninsubria.it
Fri Aug 1 05:35:04 EDT 2008
Scrive Tim Sutton <tim at linfiniti.com>:
> Hi
> The svn url you gave seems to for the top level
> dir (including hooks etc) - was that intentional? I guess its just the
> 'prova' dir that needs to go into the plugins folder?
Yes, the url I gave contains also svn stuff. I have to cleanup the repo. I
updated the wiki page with the correct url:
svn://home.prea.net/svn/GSoC/pluginProva/
> Since you have Qt4 at your fingertips look at QDir::separator() which
> will give the correct string for the OS separator. There is also a
> call on QDir::nativeSeparators(QString) which will convert a path to
> the platform native separator format. Both are static calls so you
> dont need an instance first.
in fact I answered before examining the bug... there is no backslash problem.
Instead, I have to cope with paths containing whitespaces, because R strictly
rejects them if spaces are not escaped. If the path where to save output files
doesn't contain spaces, all is going very well until now!
regards,
Anne
> Regards
> Tim
> >> I'll give some more feedback when I have tried it out!
> > I'm sure that, with present revision, on Windows systems the plugin can't
> find
> > the R scripts needed for analysis. I'll solve it next week. Let me know if
> on
> > Mac there are similar problems.
> > many thanks!
> >> Regards
> >> Tim
> > regards,
> > Anne
> >> 2008/7/29 Anne Ghisla <a.ghisla at studenti.uninsubria.it>:
> >> > Hi all, and apologies for cross-posting,
> >> > the code of my Summer of Code project is ready for beta testing!
> >> > It's a Python plugin for QGIS that estimates home ranges with different
> >> > algorithms, calling R behind the scenes.
> >> > Here is the repository:
> >> > ďťż
> >> > and here the information page (have a look at system requirements)
> >> > http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding
> >> > in the repo there is a folder named 'pluginProva'.
> >> > Download it in the QGIS user plugin folder:
> >> > (qgis_prefix)/share/qgis/python/plugins
> >> > run QGIS (better from a shell, control info and some error messages are
> >> > still not shown in the GUI) and load the new plugin via Plugin Manager.
> >> > That's all.
> >> > The plugin needs radio-tracking data, i.e. points. A generic point layer
> >> > is accepted; there must be a column that contains the same value for
> >> > groups of at least 5 points.
> >> > About requirements, I'll be glad if you test the plugin without Numeric
> >> > and with different version of all software involved.
> >> > Mac testing is particularly welcome.
> >> > I'll be glad if you document any running configuration different from
> >> > the one indicated in the wiki page.
> >> > Before releasing the 1.0 version, I have to find a suitable name for the
> >> > plugin.
> >> > My first idea is 'homerangeR', but is already the name of another
> >> > program (in different case: it's spelled HomeRanger).
> >> > http://nhsbig.inhs.uiuc.edu/home_range/ranger_readme.html#9
> >> > May I use homerangeR anyway? any suggestions?
> >> > Feedback is welcome!
> >> > kind regards,
> >> > _______________________________________________
> >> > Soc mailing list
> >> > Soc at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/soc
> >> > Qgis-developer mailing list
> >> > Qgis-developer at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Tim Sutton
> >> QGIS Project Steering Committee Member - Release Manager
> >> Visit http://qgis.org for a great open source GIS
> >> Blog: http://tim.linfiniti.com
> >> Skype: timlinux
> >> Irc: timlinux on #qgis at freenode.net
> Tim Sutton
> Skype: timlinux
