[Qgis-developer] Cleaning up stdout for 1.0.0 and qgsmaprender
renaming.
Jürgen E. Fischer
jef at norbit.de
Mon Aug 4 18:44:08 EDT 2008
Hi Tim,
On Mon, 04. Aug 2008 at 23:51:19 +0200, Tim Sutton wrote:
> Ah sorry I missed that - had you posted it somewhere?
Sure in [1], meanwhile moved it to [2]. The patch itself is outdated,
but the scripts that produce it should still work.
> In general though my feeling is that many of the debug statements
> currently in our code are actually better removed and debugging done
> with a debugger (I'm as guilty of this as anyone else).
Sure, debug output that is pure noise, should be removed. Some should
be throttled using a higher debug level (and not commented out) and
really useful ones should stay, but turned to QgsDebugMsg.
Using QgsDebugMsg just enables debug output in debug builds
(-DQGISDEBUG) - release build wouldn't have no such noise.
I think - except for debugging purposes - there should be no direct
output to cout/cerr at all in a gui application.
Jürgen
[1] http://lists.osgeo.org/pipermail/qgis-developer/2008-May/003784.html
[2] http://buten.norbit.de/~jef/cleanup/
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
