[Qgis-developer] Cleaning up stdout for 1.0.0 and qgsmaprender renaming.
Tim Sutton tim at linfiniti.com
Tue Aug 5 11:53:04 EDT 2008
Hi
Ok what I'll do is roll back my commenting out changes and wait for
you to do your script based patch to get rid of stdout etc. I will
commit my qgsmaprenderer name change and also some changes that remove
some of the more mundane debug messages.
Regards
Tim
2008/8/5 Jürgen E. Fischer <jef at norbit.de>:
> Hi Tim,
> On Mon, 04. Aug 2008 at 23:51:19 +0200, Tim Sutton wrote:
>> Ah sorry I missed that - had you posted it somewhere?
> Sure in [1], meanwhile moved it to [2].  The patch itself is outdated,
> but the scripts that produce it should still work.
>> In general though my feeling is that many of the debug statements
>> currently in our code are actually better removed and debugging done
>> with a debugger (I'm as guilty of this as anyone else).
> Sure, debug output that is pure noise, should be removed.  Some should
> be throttled using a higher debug level (and not commented out) and
> really useful ones should stay, but turned to QgsDebugMsg.
> Using QgsDebugMsg just enables debug output in debug builds
> (-DQGISDEBUG) - release build wouldn't have no such noise.
> I think - except for debugging purposes - there should be no direct
> output to cout/cerr at all in a gui application.
> Jürgen
> [1] http://lists.osgeo.org/pipermail/qgis-developer/2008-May/003784.html
> [2] http://buten.norbit.de/~jef/cleanup/
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
Blog: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
