[Qgis-developer] Planning for QGIS 1.0.0 '????'
Jürgen E. Fischer jef at norbit.de
Thu Aug 7 12:38:42 EDT 2008
Hi Marco,
On Thu, 07. Aug 2008 at 11:40:41 +0200, Hugentobler  Marco wrote:
> - GEOSGeometry seems to be GEOSGeom in geos 2. Maybe version 2 could
>   be supported by a typedef or define ?
Added - also changed for the GEOSPolygonizer_getCutEdges() call.  See
[1] for the updated patch.
> - The tool to add rings to a polygon did not work when I tested it
> - The same with the tool to add islands to selected polygons
as far as I can tell: both fixed
> Thanks anyway for doing the port to c-api. I know it is a difficult
> task because many parts in qgis depend on geos functionality.
You're welcome.
Jürgen
[1] http://trac.osgeo.org/qgis/ticket/1193
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
