[Qgis-developer] [SoC report] home range analysis in QGIS
Tim Keitt tkeitt at keittlab.org
Fri Aug 8 12:14:48 EDT 2008
On Fri, Aug 8, 2008 at 11:07 AM, Tim Sutton <tim at linfiniti.com> wrote:
> Hi
> For me I get :
> In install.packages(c("adehabitat")) :
>  package 'adehabitat' is not available
This usually happens when the Ubuntu version of R falls behind the
R-project version of R. There is no organized effort to back port CRAN
packages. Best thing to do is use the CRAN apt repository for R so you
keep in sync with CRAN packages.
My sources.list includes:
deb http://cran.stat.ucla.edu/bin/linux/ubuntu hardy/
Substitute a mirror listed at r-project.org. Then apt upgrade or
apt-get install r-base.
THK
> Fill log of what I did is here:
> http://rafb.net/p/CgxjiX68.html
> Any ideas?
> Regards
> Tim
> 2008/8/8 Tim Keitt <tkeitt at keittlab.org>:
>> Got it working. See http://www.keittlab.org/node/144
>> In R (as root if you prefer), type: "install.packages(<pkg-name>, dep
>> = T)" (dropping quotes) to install each package.
>> In Ubu, you need to "apt-get install libgdal1-dev" to build rgdal.
>> There are a bunch of qgis python dependencies I had to install as
>> well. Ubuntu has a mechanism for suggesting packages to install, but
>> AFAICT it works only with binaries. It would be nice if it could also
>> resolve python library dependencies and suggest the packages. I
>> figured out which python packages I needed by looking at the qgis
>> error messages.
>> Looks great Anne!
>> THK
>> On Fri, Aug 8, 2008 at 8:42 AM, Tim Sutton <tim at linfiniti.com> wrote:
>>> Hi Anne
>>> I updated again your plugin now from svn and it starts without error
>>> now. When I try to run it complains its missing rgdal and adehabitat.
>>> I see on your wiki page[1] you say:
>>> "R packages adehabitat and rgdal and all their dependencies"
>>> But don't offer any instructions on how to do this. Could you update
>>> it so R clueless folks like me can play too? :-)
>>> Many thanks
>>> Tim
>>> [1] http://wiki.qgis.org/qgiswiki/GSoC2008Rbinding
>>> 2008/8/8 Anne Ghisla <a.ghisla at studenti.uninsubria.it>:
>>>> Hello all,
>>>> this week I released the plugin with full functionality (revision 111).
>>>> It is available for testing.
>>>> Under Debian-alikes it works well, in Windows there are some problems due to
>>>> availability of RPy for R 2.7.1, since adehabitat R package doesn't run under R
>>>> 2.7.0. It is therefore suggested to use R 2.6.2 and corresponding RPy until a
>>>> stable RPy2 comes out.
>>>> Next week I plan to do further testing, write down documentation and think about
>>>> a tutorial. A sample dataset will also be shipped together with the code of the
>>>> plugin.
>>>> No blocks at the moment!
>>>> Happy coding to all of us,
>>>> Anne Ghisla
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Tim Sutton
>>> QGIS Project Steering Committee Member - Release Manager
>>> Visit http://qgis.org for a great open source GIS
>>> Blog: http://tim.linfiniti.com
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>> Timothy H. Keitt, Assistant Professor
>> University of Texas at Austin http://www.keittlab.org/
>> Contact info and schedule at http://www.keittlab.org/~tkeitt/
>> Publications http://www.keittlab.org/biblio
> Tim Sutton
> Skype: timlinux
