[Qgis-developer] Projection changed after loading project file.
Bob and Deb
bobdebm at gmail.com
Fri Aug 15 18:28:02 EDT 2008
Hello All,
Below is a problem that I just posted on irc. Hopefully the devs on the
list knows what is going on :-) Btw, I am running r9060 on a Ubuntu
8.04 X86_64
system with qt4.4.
Bob
<CGI617> Now I have another weird problem. I load a latlon nad27 quad map
of California and a geology map in state plane zone 3 nad27 with otf turned
on. Saved it in a project and reran qgis.
<CGI617> otf is still on and each layer pointing to the right projection,
but the layers don't over lay each other. Looking at the metadata of the
geology layer shows that the projection has changed. In the proj string
x_0=2000000 instead of 609601.2192024384.
<CGI617> I click on the layer properties general tab and click on Change CRS
and I can see that the right projection is selected. After clicking on OK
and then OK on the layer properties dialog box, I can see the geology
feature move to the correct position.
<CGI617> it seems that qgis assumes that the projection used meters instead
of feet
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080815/ae219dbb/attachment-0001.html
