[Qgis-developer] printing branch ready for testing
Gavin Macaulay gavin at macaulay.co.nz
Sun Aug 17 02:18:02 EDT 2008
Marco,
I've done some testing of the printing branch. Much improved!
I have a few comments:
- when printing the map, qgis provides no feedback on when it has finished - perhaps a busy cursor is required here?
- the legend for polygons puts the coloured rectangle below the layer name. Having the ability to have the coloured rectangle to the right of the layer name would be useful.
- if I place a few items onto the composer, then click on one of them, press the delete key, and continue doing that, when I click on the last remaining item, qgis will crash (error on console is:
QgsComposerItem::setSelected
Fatal: ASSERT failure in QList<T>::at: "index out of range", file /usr/include/QtCore/qlist.h, line 393
Aborted
- if one resizes the rectangle that surrounds an item and drags it to the left and above the top left-hand corner of the original rectangle, one gets into a situation where the rectangle no longer surrounds the item and one loses the ability to move it back :(
- sometimes the scalebar item is just a short vertical line. I haven't found a way to reliably reproduce this...
Regards
Gavin
---- Original message ----
>Date: Sat, 16 Aug 2008 17:31:14 +0200
>From: "Hugentobler  Marco" <marco.hugentobler at karto.baug.ethz.ch>
>Subject: [Qgis-developer] printing branch ready for testing
>To: <qgis-developer at lists.osgeo.org>
>Hi qgis devs,
>The printcomposer branch is ready for testing now. The branch is available with svn:
>svn co https://svn.osgeo.org/qgis/branches/advanced_printing_branch
>I'm going to compile windows binaries next week so that it is also possible to test for non-developers. The plan is to merge the printing branch to trunk prior to feature freeze for 1.0 (25. August).
>Regards,
>Marco
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-developer
