AW: [Qgis-developer] printing branch ready for testing
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Tue Aug 19 03:45:47 EDT 2008
Hi John,
Thanks for your feedback.
>After I add a map, trying to add
>another map to the composer window seems to fail
After adding one item to the composer, the active tool automatically switches to 'select'. Because usually, people want to move or resize an item after adding it. Does it work if you choose the 'addMap' Tool a second time for the second map?
>Using the print
>function, then sending the print output to OS X's Preview.app to view
>the print output caused a crash
Right, I'm going to test on Mac too.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: John C. Tull im Auftrag von John C. Tull
Gesendet: Sa 16.08.2008 20:43
An: Hugentobler  Marco
Cc: qgis-developer at lists.osgeo.org
Betreff: Re: [Qgis-developer] printing branch ready for testing
On Aug 16, 2008, at 8:31 AM, Hugentobler Marco wrote:
> Hi qgis devs,
> The printcomposer branch is ready for testing now. The branch is
> available with svn:
> svn co https://svn.osgeo.org/qgis/branches/advanced_printing_branch
> I'm going to compile windows binaries next week so that it is also
> possible to test for non-developers. The plan is to merge the
> printing branch to trunk prior to feature freeze for 1.0 (25. August).
> Regards,
> Marco
Marco,
It built and installed well on OS X 10.5.4 and Qt 4.4.1. The
attachment shows some layout issues. After I add a map, trying to add
another map to the composer window seems to fail. Using the print
the print output caused a crash. Here is some of the output, possibly
relevant:
8/16/08 11:40:33 AM [0x0-0x27a27a].org.qgis.qgis[31589] Debug: /Users/
jctull/sources/qgis/advanced_printing_branch/src/core/
qgscoordinatetransform.cpp: 193: (initialise) Source/Dest SRS equal,
shortcircuit is set.
qgsvectorlayer.cpp: 295: (drawLabels) Starting draw of labels
qgsmaprenderer.cpp: 420: (render) Rendering completed in (seconds):
9.188
8/16/08 11:40:52 AM com.apple.launchd[408]
([0x0-0x27a27a].org.qgis.qgis[31589]) Exited abnormally: Segmentation
fault
I can do some more testing as you progress, but will be in and out of
touch for the next several days.
Regards,
John
