AW: [Qgis-developer] printing branch ready for testing
John C. Tull john.tull at wildnevada.org
Wed Aug 20 13:52:55 EDT 2008
On Aug 20, 2008, at 10:46 AM, John C. Tull wrote:
> On Aug 19, 2008, at 12:45 AM, Hugentobler Marco wrote:
>> Hi John,
>> Thanks for your feedback.
>>> After I add a map, trying to add
>>> another map to the composer window seems to fail
>> After adding one item to the composer, the active tool
>> automatically switches to 'select'. Because usually, people want to
>> move or resize an item after adding it. Does it work if you choose
>> the 'addMap' Tool a second time for the second map?
> No, this happens after selecting the "Add Map Item" tool. When I
> select that tool, then draw a rectangle on the canvas, nothing
> happens. No debug output and the rectangle disappears. There are no
> new items added to the canvas.
> I can add labels and legends, just not additional map items.
> John
After grouping a map item with a legend, then moving the grouped item
(not sure if the latter part made a difference), I was then able to
add a new map item as expected. If you have a Mac, this might be
something to try to help work out the issue.
John
