[Qgis-developer] new print composer issues
Maciej Sieczka tutey at o2.pl
Mon Aug 25 10:18:20 EDT 2008
Hi Marco,
Testing the new composer's cool features I discovered the following
problems:
0. Polygon fill is still broken in the output e.g. PDF), as it's been
for the old composer.
1. Label buffering is corrupted in the output (same as it was too).
2. Label offsets in the composer, in the output and on the QGIS map
canvas do not match each other (i.e. the distance between the object and
it's label is different in all of them, for a given label offset setting).
3. "Refresh view" does not redraw the print composer fully. E. g. add an
SVG image, put a path to another one in it's properties, refresh the
view - no change; now move the image - and it refreshes).
Request - could the mouse scroll have the same function it has defined
in QGIS main properties? So that e.g. the zoom on scroll worked?
Maciek
Maciej Sieczka
www.sieczka.org
