[Qgis-developer] new print composer issues
Maciej Sieczka tutey at o2.pl
Tue Aug 26 06:23:59 EDT 2008
Maciej Sieczka pisze:
>>> Testing the new composer's cool features I discovered the
>>> following problems:
7. Fooling around I ended up with some 2 weird frames (see the attached
screendump) that I could not get rid of in any way. They are not
render-artifacts (refreshing and panning around does not purge them),
but they are not normal, selectable objects either. Saving the project
and re-opening it drops them.
8. If the paper setup is "landscape" and I press the "full extent"
button, unnecessary scrollbars crop out. Moreover, in "landscape" mode
I'm not able to scroll right to see the black paper border; in
"portrait" mode it's bottom border that can't be reached, respectively.
Maciek
Maciej Sieczka
www.sieczka.org
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080826/db5e044e/weird_frames.png
