[Qgis-developer] Qt4 Port of Almost All GRASS Plugin/Provider
Tim Sutton
tim at linfiniti.com
Tue Aug 26 15:37:32 EDT 2008
Hi Tom
In the grass tidy up branch, I also worked on porting grass shell
class to qt4. As you said there are a lot of complications with the
port and what I have there works to some extent but isnt bug free
either. Perhaps its useful for your shell work though - if not or you
have a better approach thats fine too.
I will try to test your patch here on ubuntu over the coming day or two.
Regards
Tim
2008/8/26 Tom Elwertowski <telwertowski at comcast.net>:
> Hello GRASS Users,
> I have removed Qt3 classes from all of the GRASS plugin/provider except the
> GRASS shell.
> A patch is available for testing from:
> http://telwertowski.home.comcast.net/grass_noqt3_r9170.diff
> If this works for others, I will submit it to svn.
> I have also ported the last remaining Qt3 class, qgsgrassshell, but it still
> has bugs due to a major redesign of QTextEdit. I might get back to it in a
> few weeks or I can make it available for someone else to work on now.
> Tom
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
