[Qgis-developer] no plugin installer present
Carlos Dávila cdavilam at jemila.jazztel.es
Thu Aug 28 09:17:56 EDT 2008
Otto Dassau escribió:
> Hi Tim,
> On Thu, 28 Aug 2008 07:25:22 +0200
> "Tim Sutton" <tim at linfiniti.com> wrote:
>> Hi Otto
>> I have been building with qt4 on ubuntu for some time.
> ok, I guess my problems are homemade. If I don't manage to fix it, I will write
> again.
If you find a solution please write it here, as you are not the only one
with this issue.
Regards
Carlos
> thanks a lot
>  Otto
>> regards
>> tim
>> On 8/27/08, Otto Dassau <otto.dassau at gmx.de> wrote:
>>> Hi,
>>> I have the same (similar) problem building packages on debian lenny and
>>> OpenSUSE
>>> SLE_10 and 10.2 using QT 4.4.x. packages.
>>> ######## Warnings and Python not being built messages ...
>>> CMake Warning (dev) at CMakeLists.txt:257 (ADD_DEFINITIONS):
>>> Policy CMP0005 is not set: Preprocessor definition values are now escaped
>>> automatically. Run "cmake --help-policy CMP0005" for policy details. Use
>>> the cmake_policy command to set the policy and suppress this warning.
>>> This warning is for project developers. Use -Wno-dev to suppress it.
>>> CMake Warning (dev) at CMakeLists.txt:258 (ADD_DEFINITIONS):
>>> CMake Warning (dev) at CMakeLists.txt:259 (ADD_DEFINITIONS):
>>> CMake Warning (dev) at src/providers/grass/CMakeLists.txt:1
>>> (ADD_DEFINITIONS):
>>> CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:4 (ADD_DEFINITIONS):
>>> CMake Warning (dev) at src/plugins/grass/CMakeLists.txt:21
>>> (ADD_DEFINITIONS):
>>> QGIS builds but then I don't have python incl. the plugin installer
>>> available
>>> with the error message like this on a debian lenny starting qgis
>>> #PyQGIS konnte nicht geladen werden.
>>> #Die Python-Unterstützung wird abgeschaltet.
>>> #Traceback (most recent call last):
>>> #  File "", line 1, in
>>> #ImportError: No module named qgis.core
>>> #Python-Version:
>>> #2.5.2 (r252:60911, Aug 16 2008, 14:40:27)
>>> #[GCC 4.3.1]
>>> #Python-Pfad:
>>> #['/python', '/home/dassau/.qgis//python/plugins', '/python/plugins',
>>> #'/usr/lib/python25.zip', '/usr/lib/python2.5',
>>> #'/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
>>> #'/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages',
>>> #'/usr/lib/python2.5/site-packages',
>>> '/usr/lib/python2.5/site-packages/Numeric',
>>> #'/usr/lib/python2.5/site-packages/PIL',
>>> #'/usr/lib/python2.5/site-packages/gst-0.10',
>>> #'/var/lib/python-support/python2.5',
>>> #'/usr/lib/python2.5/site-packages/gtk-2.0',
>>> #'/var/lib/python-support/python2.5/gtk-2.0']
>>> at http://lists.osgeo.org/pipermail/qgis-user/2008-August/003289.html
>>> people said they had to downgrade python-qt4 package to version 4.3.3. to
>>> make
>>> it work.This would be really bad for me since I am just preparing the
>>> opensuse
>>> build server to create all QGIS 1.0 opensuse rpms with a current QT4 (4.4.x)
>>> version.
>>> So my question :): Is my plan possible at all to build QGIS with QT4
>>> (4.4.x).
>>> Is there a solution to fix this or which QT versions work at the moment?
>>> thanks a lot
>>>  Otto
>>> On Wed, 20 Aug 2008 14:28:14 +0200
>>> Maciej Sieczka <tutey at o2.pl> wrote:
>>>> Maciej Sieczka pisze:
>>>>>> In current trunk (r9046) the plugin installer plugin is not present in
>>>>>> the plugins manager menu. What's wrong?
>>>>> After a rebuild from SVN today, I have the Plugin Installer present.
>>>> ... and after another rebuild yesterday it's gone again. Same as the
>>>> Python console. What's up?
>>>>> When is the 0.05.4 from
>>>>> http://bwj.aster.net.pl/qgis/plugins.xml going to be included?
>>>> (Bump.) Feature freeze is near. It could use some testing.
>>>> Maciek
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Por favor, no me envíe documentos con extensiones .doc, .docx, .xls, .xlsx, .ppt, .pptx, .mdb, mdbx
Instale OpenOffice desde http://es.openoffice.org/programa/index.html
OpenOffice es libre: se puede copiar, modificar y redistribuir libremente.
OpenOffice es gratis.
El uso de OpenOffice es totalmente legal.
OpenOffice funciona mejor que otros paquetes de oficina.
OpenOffice está en continuo desarrollo y no tendrá que pagar por las nuevas versiones.
