[Qgis-developer] QGIS 0.11.0 crashes when clicking on the
projection-selector
Stephan Holl
stephan.holl at intevation.de
Fri Aug 29 02:51:02 EDT 2008
Hello QGISSers,
while using the new RPM-packages for Suse I enconutered a crash (on
SLE10) when hitting the projection-selector on the bottom right of the
qgis-screen.
The message is as follows, perhaps helpful for you:
qgis: /usr/src/packages/BUILD/qgis-0.11.0/src/gui/qgsprojectionselector.cpp:610:
void QgsProjectionSelector::applyProjList(QSet<QString>*): Zusicherung
»rc == 0« nicht erfüllt.
Does this has something to do with packaging or is this a more deeper
problem (or even solved upstream)?
Best regards and thanks in advance.
Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080829/2384d026/signature.bin
