[Qgis-developer] Requirement for int4 column on PostGIS access
Jürgen E. Fischer jef at norbit.de
Sat Aug 30 22:09:03 EDT 2008
Hi Jochen,
On Sat, 30. Aug 2008 at 16:42:42 +0200, Jochen Topf wrote:
> Currently QGIS requires a int4 column with unique IDs for accessing data
> in a PostGIS database. I routinely work with OpenStreetMap data which
> uses int8 for its IDs. Currently the OSM IDs still fit into an int4, but
> this will not work forever. At the moment its a bit of a hassle that I
> always have to keep this limitation in mind.
BTW there is a bug report about this: https://trac.osgeo.org/qgis/ticket/62
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
