[Qgis-developer] Re: [QGIS Commit] r9685 - trunk/qgis/src/core/renderer
Tim Sutton tim at linfiniti.com
Sun Dec 14 02:12:34 EST 2008
Hi
Its set to 0.26 in trunk now...
Regards
Tim
On Sun, 2008-12-07 at 21:26 +0100, Maciej Sieczka wrote:
> Tim Sutton pisze:
> >> Thanks Tim for looking into this. Now there are 3 different default
> >>  width settings - "Unique Value" uses 0.1, "Continous color" 0.4
> >> and the other two 0.2 as I suggested. Please unify this id
> >> possible. Thanks again.
> > Done in r9710
> Another problem now. 0.2 is not wide enough when neither "Fix
> problems..." nor "Make lines appear less jagged..." are set in rendering
> options. For 0.2 outline there are gaps in lines - see the ticket [1]
> and screendumps attached to it.
> A minimum outline width at which the issue is gone in all cases that I
> checked is 0.26. Is this a feature or a bug? If a feature, I think QGIS
> should default to 0.26 for a workaround.
> Maciek
> [1]https://trac.osgeo.org/qgis/ticket/1447
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20081214/30dd794d/attachment.bin
