[Qgis-developer] please help me write a QGIS-PostGIS GUI in Python
Maciej Sieczka tutey at o2.pl
Fri Feb 1 15:41:55 EST 2008
Barry Rowlingson pisze:
>  For example, there's a bunch of 'autoconnected' slots which are
> connected to GUI objects (buttons and so on) such as:
> // Slot for adding a new connection
> void QgsDbSourceSelect::on_btnNew_clicked()
>   addNewConnection();
>  - so that when the 'New' button is clicked it calls the
> addNewConnection method. In Python code this would be a method in the
> Dialog class above, like:
>   def on_btnNew_clicked(self):
>     self.addNewConnection()
>  and then you have to write the addNewConnection method as well.
> Now, I'm not sure if this autoconnected slot business works in Python...
I can't make the "Connect" button call the addNewConnection from Python.
Can you, or anybody, give a working example of how to do this? My code
actually looks like in the attachment. It's enough to spawn the main
plugin GUI, but I can't figure out how to to make it's buttons call the
existing QGIS C++ functionality, besides that which is already available
in *.sip files.
For example, it's easy to do:
from qgis.core import QgsContextHelp
   def on_pbnHelp_clicked(self):
     QgsContextHelp.run(32338213)
but how do I call addNewConnection? Or is it impossible, when the given
C++ functionality is not in *.sip?
Maciek
Type: application/x-bzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080201/f4b08b84/qgis_postgis_v2.tar.bin
