[Qgis-developer] custom attribute inserting/editing
Alessandro Pasotti
apasotti at gmail.com
Fri Feb 15 09:09:47 EST 2008
2008/2/15, Martin Dobias <wonder.sk at gmail.com>:
> On Wed, Feb 13, 2008 at 3:24 PM, Bud P. Bruegger <bud at comune.grosseto.it> wrote:
> > I am looking into the possibility of custom attribute editing, i.e.,
> > So my questions are:
> > * is this feasible?
> Yes, I think so. If I understand correctly what you want is to show a
> dialog for a feature which will show the fields with according
> (customized) editing widgets.
> With Qt there's no problem to create dialogs on the fly, for example
> in GRASS plugin QGIS shows forms for GRASS modules in such way - the
> definition of the form is always stored in an XML file which is read
> and the form is created accordingly.
> > * is this something a python programmer without GUI experience can do
> > (i.e., I)?
Hi, if I understand correctly, you are saying that it is possible
right now to substitute the default attribute editing window (that
contains a simple table) whit a custom one written in pyQT, if yes,
how?
Typical use case 1: a user inserts a new postgis feature and a causotm
editing form is displayed instead of the default one
use case 2: using the identify tool on a postgis layer feature, to
display a custom form into which the user can view/edit the
attributes.
It would be really great if it were already possible.
Regards.
Alessandro Pasotti
w3: www.itopen.it
