[Qgis-developer] GDAL/OGR C API Port
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Sat Feb 16 02:34:09 EST 2008
Hi Frank,
Many thanks for doing the C++ -> C-api port!
My suggestion is that we should wait one or two weeks to give developers the
possibility to test.
http://wiki.qgis.org/qgiswiki/DevelopersManual#head-a09fe76302fc8576558e3e2b3f206165f1b0302c
describes the procedure for merging branches. It's also written that binary
packages should be built to let non-developers test. Tim, is it possible for
the release team to make binary builds or do you think that this would be
overkill in this case?
Regards,
Marco
Am Samstag 16 Februar 2008 04:16:42 schrieb Frank Warmerdam:
> Folks,
> I believe I have completed the port of QGIS to the GDAL/OGR C API in
> the gdalogr-capi-branch.  Due to limited familiarity with QGIS it is hard
> for me to be sure things are working right.  I've loaded some raster and
> vector data through GDAL and OGR in QGIS and it seems to work ok.
> Is there a regression test suite that will meaningfully help for this?
> How/when do I get the changes ported back into trunk?
> Best regards,
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
