[Qgis-developer] Adding Attributes to Vector Layor (QGIS 0.9.1)
nathan leverington nleverin at gmail.com
Sun Feb 17 19:14:42 EST 2008
Hi all,
Im new qgis and gis in general so sorry for the newbie question.
im currently having a problem with adding attributes to the vector layor.
Im using qgis 0.9.1 development libraries and creating my own application
using Open Suse 10.3.  I was following Tim Sutton tutorial 6 to implement
this but have noticed that QgsFeatureAttribute class has been removed from
the 0.9.1 release.
I have changed the the tutorial code:
*    while ((mypFeature = mypProvider->getNextFeature**(true)))
      //get the attributes of this feature
      const std::vector < QgsFeatureAttribute >& myAttributes =
mypFeature->attributeMap();
      for (int i = 0; i < myAttributes.size(); i++)*
with the following:
*    //now iterate through each feature
    while (mypProvider->getNextFeature(mypFeature))
      // const std::vector < QgsFeatureAttribute >& myAttributes =
      const QgsAttributeMap& myAttributes = mypFeature.attributeMap();
      if( myAttributes.isEmpty() ) cout << "attribute map is empty " <<
endl;*
Iv tried replacing the  QgsFeatureAttribute with the QgsAttributeMap, but
when calling the attributeMap() function i do not seem to be pulling in the
attribute data.
Is this a problem with the shapefile datastore.  (i.e. i am using the same
source shapefile data that was used for Tim's tutorial 6)
thanks in advance,
nlev.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080218/75a1a748/attachment.html
