[Qgis-developer] Python Geprocessing Plugin
John C. Tull john.tull at wildnevada.org
Mon Feb 18 12:22:22 EST 2008
Düster,
Great work. I will certainly be testing and using this plugin. Thanks
for the coding effort!
John
On Feb 17, 2008, at 2:30 AM, Düster Horst wrote:
> A new Geoprocressing Python plugin is available in the Python Plugin
> Repository.
> http://spatialserver.net:3001
> This plugin  is under developement and offers vector analysis
> functions for ogr and postgis vector data.
> The following functions are available:
>  - Buffer
>  - Convex Hull
>  - Difference A - B
>  - Dissolve
>  - Intersection
> under developement:
>  - SymDifference
>  - Union
> The plugin needs QGIS Rev. 8153 or higher!
> The plugin uses the GEOS library. I recommend the use of GEOS-3.0.0.
> Unfortunately there are some issues with GEOS. In some cases GEOS
> throws topology exceptions when you try to dissolve large datasets
> => QGIS crashes.
> I hope that this plugin can be helpful for you and I look forward
> for your comments and ideas.
> Regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
