[Qgis-developer] GDAL/OGR C API Port
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Tue Feb 26 08:45:01 EST 2008
Hi Frank,
I'm using the gdalogr-capi-branch for quite some time now and it works
perfectly. So my suggestion is that you go ahead and merge the branch to
trunk if there is no objection on the devel list in the next two days.
cheers,
Marco
Am Samstag 16 Februar 2008 04:16:42 schrieb Frank Warmerdam:
> Folks,
> I believe I have completed the port of QGIS to the GDAL/OGR C API in
> the gdalogr-capi-branch.  Due to limited familiarity with QGIS it is hard
> for me to be sure things are working right.  I've loaded some raster and
> vector data through GDAL and OGR in QGIS and it seems to work ok.
> Is there a regression test suite that will meaningfully help for this?
> How/when do I get the changes ported back into trunk?
> Best regards,
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
