[Qgis-developer] Branch conflict
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Mon Jan 7 04:04:28 EST 2008
Hi Magnus, Tim, Steven,
A solution could be that you merge the two branches into one and work in the same branch then. Like this you detect code conflicts and/or possibilities for collaboration earlier.
A disadvantage however could be that one new feature could be ready for merge with trunk before the second one is. In this case, the merge of feature one would be delayed.
In any case, you should keep each other up to date about your current work to avoid duplication of efforts.
Best regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.qgis.org im Auftrag von Magnus Homann
Gesendet: Mo 07.01.2008 08:47
An: qgis-developer
Betreff: [Qgis-developer] Branch conflict
It seems there will be some serious conflict between branches 'renderer'
and 'composer_redesign' when/if a merger to trunk is done.
The render branch is Tim and myself fixing the render GUI and adding
rotation and scaling to the renderers. In the 'composer_redesign' branch
Steven seems to also heaviliy modify the render component.
I'm a bit worried some of these changes will be lost when the branches
are merged. How can this situation best be resolved?
Magnus
Qgis-developer mailing list
Qgis-developer at lists.qgis.org
http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
