[Qgis-developer] plugins installer
lami at faunalia.it lami at faunalia.it
Tue Jan 8 06:06:41 EST 2008
>   I submitted a trac bug report for what is probably the same issue.
>   When the python code tries to unzip the files from the zip, it fails
> if the top-level folder isn't an item in the zip. At least on Windows
> anyway.
>   See the trac bug for details. The fix is to check the paths for '/'
> and create directories that way. Not yet implemented...
> Barry
I have the same problem in Windows also for Copyrigth plugin.
But I see an other problem about Python plugins in Windows.
If I load a plugin (for example "ghydraulic") from "Python plugin
manager", the plugin directory is saved in C:\Documents and
Settings\leo\.qgis\python\plugins.
If then I open th Plugin Manager, QGIS say:
Couldn't load plugin "ghydraulic"
 File "", line 3, in
ImportError: No module named ghydraulic
and yhe plugin is not present in the plugin manager list.
If I copy or shift the ghydraulic plugin directory from C:\Documents and
Settings\leo\.qgis\python\plugins to
C:\Programmi\Quantum_GIS\python\plugins
all work rigth.
PS: Martin, this also for ARPAT plugin!
Regards
Leonardo
