[Qgis-developer] R: WinGRASS Building Instructions And QGIS Compile Enviroment
Marco Pasetti marco.pasetti at alice.it
Thu Jan 24 15:56:50 EST 2008
Hi Tim,
I found INSTALL.t2t at
https://svn.qgis.org/repos/qgis/trunk/qgis/INSTALL.t2t
How can I modify the document (indicating where I placed modifications) and
then how can I propose my changes?
Regards,
Marco
-----Messaggio originale-----
Da: Tim Sutton [mailto:tim at linfiniti.com]
Inviato: giovedì 24 gennaio 2008 17.33
A: marco.pasetti at alice.it
Cc: qgis-developer at lists.qgis.org
Oggetto: Re: [Qgis-developer] WinGRASS Building Instructions And QGIS
Compile Enviroment
Hi Marco
Ideally changes to the building from source procedure should be submitted as
a patch to INSTALL.t2t which is the master document that the INSTALL text
docuemnt and BuildingFromSource wiki page get generated from. You can fine
INSTALL.t2t in the top level of the QGIS svn checkout.
Regards
Tim
2008/1/24, marco.pasetti at alice.it <marco.pasetti at alice.it>:
> Hi,
> in WinGRASS Current Status (from GRASS wiki) I read as follows:
> After compiling [GRASS] you should copy libxdr.dll, libproj.dll,
> libpng.dll, libgdal-1.dll and libz.dll.1.2.3 into the GRASS lib
> directory and all the GDAL and PROJ .exe files in the bin directory
> into the GRASS bin directory, and then you have a more or less
self-contained GRASS distribution.
> is that necessary even if I want to use grass only with grass plug-in
> in QGIS?
> Thanks
> PS: I'm building qgis+grass by myself on windows, creating my own msys
> enviroment; I'm also in contact with grass-dev list, and I think that
> some instructions in http://wiki.qgis.org/qgiswiki/BuildingFromSource
> should be fixed. What should I do?
> Thanks
> Marco
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager Visit
http://qgis.org for a great open source GIS openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological niche
modelling tool Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
