[Qgis-developer] Re: Labels in OS X
Tom Elwertowski
telwertowski at comcast.net
Fri Jul 11 12:53:31 EDT 2008
The only parameter I use with Qt configure is -universal. Is text being truncated in the demo and example apps that come with Qt? This would determine if the problem is in Qt or qgis.
Next I would check what string is extracted from the feature at QgsLabel::renderLabel line 106. You can work forward or backward from this point depending upon whether or not you see the full string.
Tom
John C. Tull wrote:
> Thanks for the test. I just cannot think what is causing my problems
> with labels on the canvas... Care to share your Qt configure arguments?
> Maybe there's a problem there, although I tried the binary installer as
> well as home-rolled with the same label problem in either situation.
> Cheers,
> John
> On Jul 9, 2008, at 11:30 PM, Tom Elwertowski wrote:
>> John,
>> Labels work for me using current svn, Qt 4.4.0 and OS X 10.5.4. I
>> don't use Python. Trying to match your example, all I did was select a
>> label field in the Vector Layer Properties dialog and check Buffer
>> Labels.
>> Tom
>> John C. Tull wrote:
>>> Tom,
>>> I was wondering if you have been seeing problems with labels in qgis
>>> using qt-4.4.0, pyqt-4.4.2? Below is an example of how my labels are
>>> being truncated to rightmost characters in the map canvas. It seems
>>> to be something like a 50% truncation, so long labels show more
>>> characters than short labels, but everything is being cut short.
>>> Someone on irc and linux with qt-4.4.0 did not have this problem, so
>>> I am trying to see if this is happening with other Mac users.
>>> I have built the most current svn, am on 10.5.4, and seemed to only
>>> have this problem after upgrading Qt.
>>> Regards,
>>> John
