[Qgis-developer] Re: Labels in OS X
John C. Tull
john.tull at wildnevada.org
Sat Jul 12 01:08:12 EDT 2008
I rebuilt, this time with demos and examples. I cannot find anything
out of the ordinary perusing the examples and demos, but I'm not sure
if there is anything quite like the labels used for vector items in
qgis. If you know of a specific example, I'll do some more testing.
Otherwise, I'm stymied.
Regarding the string check, I'm not sure how to test that.
Thanks,
John
On Jul 11, 2008, at 9:53 AM, Tom Elwertowski wrote:
> The only parameter I use with Qt configure is -universal. Is text
> being truncated in the demo and example apps that come with Qt? This
> would determine if the problem is in Qt or qgis.
> Next I would check what string is extracted from the feature at
> QgsLabel::renderLabel line 106. You can work forward or backward
> from this point depending upon whether or not you see the full string.
> Tom
> John C. Tull wrote:
>> Thanks for the test. I just cannot think what is causing my
>> problems with labels on the canvas... Care to share your Qt
>> configure arguments? Maybe there's a problem there, although I
>> tried the binary installer as well as home-rolled with the same
>> label problem in either situation.
>> Cheers,
>> John
>> On Jul 9, 2008, at 11:30 PM, Tom Elwertowski wrote:
>>> John,
>>> Labels work for me using current svn, Qt 4.4.0 and OS X 10.5.4. I
>>> don't use Python. Trying to match your example, all I did was
>>> select a label field in the Vector Layer Properties dialog and
>>> check Buffer Labels.
>>> Tom
>>> John C. Tull wrote:
>>>> Tom,
>>>> I was wondering if you have been seeing problems with labels in
>>>> qgis using qt-4.4.0, pyqt-4.4.2? Below is an example of how my
>>>> labels are being truncated to rightmost characters in the map
>>>> canvas. It seems to be something like a 50% truncation, so long
>>>> labels show more characters than short labels, but everything is
>>>> being cut short.
>>>> Someone on irc and linux with qt-4.4.0 did not have this problem,
>>>> so I am trying to see if this is happening with other Mac users.
>>>> I have built the most current svn, am on 10.5.4, and seemed to
>>>> only have this problem after upgrading Qt.
>>>> Regards,
>>>> John
