[Qgis-developer] Plugin Installer
Alex Mandel tech_dev at wildintellect.com
Tue Jul 15 14:04:48 EDT 2008
Borys Jurgiel wrote:
> Hello List,
> Today I've rewieved and slightly polished the gui and improved the behaviour
> when installed plugin is invalid. Now the Installer displays an error log and
> suggests to uninstall the plugin immediatelly or contact the qgis-users list.
> Furthermore, since now it recognizes when QGIS is offline and raises no more
> connection errors.
> For few weeks I haven't observed any bad issues and haven't received any bug
> reports, so I think now it's enough resistant to connection errors and
> various syntax of metadata. For example, it should properly compare the
> version numbers, including all typycal prefixes, suffixes, dots, dashes,
> underlines etc. Further improvements will be implementing next to some SIP
> bindings.
> If there is nobody opposed, we can put it to the SVN. But first I would like
> to ask you, could somebody take a look at the strings and correct language
> errors...? :) I'm not unerring in English, as you can see here ;) Here is the
> full list of the strings in plain text and html:
> http://www.bwj.aster.net.pl/qgis/newplugininstaller-strings.txt
> http://www.bwj.aster.net.pl/qgis/newplugininstaller-strings.html
Spell check is pretty good. Grammar seemed fine to me.
uninstallation -> uninstall
omited -> omitted
Alex
