[Qgis-developer] Planning for QGIS 1.0.0 '????'
Jürgen E. Fischer jef at norbit.de
Wed Jul 30 16:59:02 EDT 2008
On Sun, 27. Jul 2008 at 23:02:27 +0200, Jürgen E. Fischer wrote:
> QgsGeometry is almost done - except for
> QgsGeometry::splitPolygonGeometry(), where cut edges are queried which
> is currently not supported in the C-API.  I'll propose a patch to add
> that to the C-API.
I posted the proposal[1] including a patch[2]. The QGIS patch is on [3].
QGIS patch summary:
- cmake now looks for the geos_c instead of the geos library
- QgsGeometry ported to GEOS C-API (needs geos patch [1])
- QgsSpatialIndex now catches (and ignores) exceptions
- removed (previously unused?) references to the GEOS geometry factory from
  QgsOgrProvider
- QgsWfsProvider now uses QgsSpatialIndex instead of GEOS spatial index.
Should this go to a separate branch or do I simply commit it to trunk?  I'd say
it's more likely that it gets the testing it needs in trunk...
Jürgen
[1] http://lists.osgeo.org/pipermail/geos-devel/2008-July/003416.html
[2] http://buten.norbit.de/~jef/geos.diff.r2047
[3] http://buten.norbit.de/~jef/qgis-geos.diff
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
