[Qgis-developer] QGIS Python support in a library
John C. Tull john.tull at wildnevada.org
Fri Jun 6 13:43:38 EDT 2008
Does this translate to something that can be modified in the base code
to get proper functionality in a build of qgis without the need to
hand edit files for the @loader_path stuff? I really would like to
have python plugins that work in my builds, and greatly appreciate
William's detective work and ability to make binaries that do provide
full python functionality. Unfortunately, I do not understand what
needs to be done on my end to get the same functionality. I would
probably make the necessary changes to the @executable_path issues,
but I am not clear on how to go about this.
Cheers,
John
On Jun 1, 2008, at 2:18 PM, William Kyngesburye wrote:
> OK, finally got a package built properly.  Python support IS
> starting.  Maybe something changed in SVN since I last tried it
> Saturday?  Or maybe my @loader_path change was the key?
> Qgis SVN r8575
> OSX 10.5.3, Xcode 3.1 beta
> System Python 2.5
> Qt 4.3.5/PyQt 4.3.3/SIP 4.7.4
> This is with my usual changing things to @loader_path where
> appropriate, so the python .so's in Qgis relatively refer to the
> Qgis libs and bundled Qt (instead of the default @executable_path,
> which is unclear what the executable is).
> >>> sys.path
> ['/Applications/qgis0.11.0.app/Contents/MacOS/share/qgis/python', '/
> Users/kyngchaos/.qgis//python/plugins', '/Applications/
> qgis0.11.0.app/Contents/MacOS/share/qgis/python/plugins', '/Library/
> Python/2.5/site-packages/GDAL-1.5.2-py2.5-macosx-10.5-i386.egg', '/
> System/Library/Frameworks/Python.framework/Versions/2.5/lib/
> python25.zip', '/System/Library/Frameworks/Python.framework/Versions/
> 2.5/lib/python2.5', '/System/Library/Frameworks/Python.framework/
> Versions/2.5/lib/python2.5/plat-darwin', '/System/Library/Frameworks/
> Python.framework/Versions/2.5/lib/python2.5/plat-mac', '/System/
> Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-
> mac/lib-scriptpackages', '/System/Library/Frameworks/
> Python.framework/Versions/2.5/Extras/lib/python', '/System/Library/
> Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/
> python2.5/lib-dynload', '/Library/Python/2.5/site-packages', '/
> Library/Python/2.5/site-packages/PIL', '/Library/Python/2.5/site-
> packages/geos', '/System/Library/Frameworks/Python.framework/
> Versions/2.5/Extras/lib/python/PyObjC']
> On May 31, 2008, at 12:10 PM, Tom Elwertowski wrote:
>> On May 30, 2008, at 11:27 PM, Tim Sutton wrote:
>>> I got the python stuff building and my mac post build scripts fix
>>> up all the lib paths (see below) in the libqgispython.dylib, core
>>> and gui python libs, but python stuff still wont load at
>>> runtime...not sure what to do next.
>> The QLibrary statement at qgisapp.cpp:363 needs a full path (or at
>> least something more than "qgispython"
>> QLibrary pythonlib("/Users/tce/developer/qgis/trunk/build/
>> qgis0.11.0.app/Contents/MacOS/lib/libqgispython.dylib");
>> works for me but SVN needs a somewhat more generic solution.
>> Tom
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would not
> deign to possess - money to purchase the effeminate pleasures of
> weaklings.  And yet withal bound down by silly customs that make
> them slaves to their unhappy lot while firm in the belief that they
> be the lords of creation enjoying the only real pleasures of
> existence....
> - the wisdom of Tarzan
