[Qgis-developer] QGIS Python support in a library
John C. Tull john.tull at wildnevada.org
Fri Jun 6 15:24:42 EDT 2008
I'll look at them and try to make edits for using William's binaries.
Once I see the logic in application, it should be easy enough to
modify to my needs.
Thanks,
John
On Jun 6, 2008, at 11:35 AM, Tim Sutton wrote:
> Hi
> Once I have my scripts working right, Ill check them into svn and if
> you are using my build des tarball for mac you should be able to bake
> your own mac app bundle (sans grass support).
> Regards
> Tim
> 2008/6/6 John C. Tull <john.tull at wildnevada.org>:
>> Does this translate to something that can be modified in the base
>> code to
>> get proper functionality in a build of qgis without the need to
>> hand edit
>> files for the @loader_path stuff? I really would like to have
>> python plugins
>> that work in my builds, and greatly appreciate William's detective
>> work and
>> ability to make binaries that do provide full python functionality.
>> Unfortunately, I do not understand what needs to be done on my end
>> to get
>> the same functionality. I would probably make the necessary changes
>> to the
>> @executable_path issues, but I am not clear on how to go about this.
>> Cheers,
>> John
>> On Jun 1, 2008, at 2:18 PM, William Kyngesburye wrote:
>>> OK, finally got a package built properly.  Python support IS
>>> starting.
>>> Maybe something changed in SVN since I last tried it Saturday?  Or
>>> maybe my
>>> @loader_path change was the key?
>>> Qgis SVN r8575
>>> OSX 10.5.3, Xcode 3.1 beta
>>> System Python 2.5
>>> Qt 4.3.5/PyQt 4.3.3/SIP 4.7.4
>>> This is with my usual changing things to @loader_path where
>>> appropriate,
>>> so the python .so's in Qgis relatively refer to the Qgis libs and
>>> bundled Qt
>>> (instead of the default @executable_path, which is unclear what the
>>> executable is).
>>>>>> sys.path
>>> ['/Applications/qgis0.11.0.app/Contents/MacOS/share/qgis/python',
>>> '/Users/kyngchaos/.qgis//python/plugins',
>>> '/Applications/qgis0.11.0.app/Contents/MacOS/share/qgis/python/
>>> plugins',
>>> '/Library/Python/2.5/site-packages/GDAL-1.5.2-py2.5-macosx-10.5-
>>> i386.egg',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/
>>> python25.zip',
>>> python2.5',
>>> python2.5/plat-darwin',
>>> python2.5/plat-mac',
>>> python2.5/plat-mac/lib-scriptpackages',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/
>>> lib/python',
>>> python2.5/lib-tk',
>>> python2.5/lib-dynload',
>>> '/Library/Python/2.5/site-packages',
>>> '/Library/Python/2.5/site-packages/PIL',
>>> '/Library/Python/2.5/site-packages/geos',
>>> lib/python/PyObjC']
>>> On May 31, 2008, at 12:10 PM, Tom Elwertowski wrote:
>>>> On May 30, 2008, at 11:27 PM, Tim Sutton wrote:
>>>>> I got the python stuff building and my mac post build scripts
>>>>> fix up all
>>>>> the lib paths (see below) in the libqgispython.dylib, core and
>>>>> gui python
>>>>> libs, but python stuff still wont load at runtime...not sure
>>>>> what to do
>>>>> next.
>>>> The QLibrary statement at qgisapp.cpp:363 needs a full path (or
>>>> at least
>>>> something more than "qgispython"
>>>> QLibrary
>>>> pythonlib("/Users/tce/developer/qgis/trunk/build/qgis0.11.0.app/
>>>> Contents/MacOS/lib/libqgispython.dylib");
>>>> works for me but SVN needs a somewhat more generic solution.
>>>> Tom
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
>>> fighting,
>>> and all for things that the beasts of the jungle would not deign
>>> to possess
>>> - money to purchase the effeminate pleasures of weaklings.  And
>>> yet withal
>>> bound down by silly customs that make them slaves to their unhappy
>>> lot while
>>> firm in the belief that they be the lords of creation enjoying the
>>> only real
>>> pleasures of existence....
>>> - the wisdom of Tarzan
> Tim Sutton
> QGIS Project Steering Committee Member - Release Manager
> Visit http://qgis.org for a great open source GIS
> openModeller Desktop Developer
> Visit http://openModeller.sf.net for a great open source ecological
> niche modelling tool
> Home Page: http://tim.linfiniti.com
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
