[Qgis-developer] SoC: GUI actions
Borys Jurgiel borys at wolf.most.org.pl
Tue Jun 24 04:56:28 EDT 2008
They both are the same. After work in the QtDesigner you run the pyuic4, which
creates a class for your dialog (for example "Ui_Dialog") and puts into this
class the "connect" method call (or rather a number of calls).
Then you create your own class, which inherites from the pyuic4's class (for
example: "MyDialog (QDialog, Ui_Dialog)" ) and you can also put the "connect"
method call(s) to the your class. So only one difference is where this call
finally is: in the parent or in the inherited class.
For me the second option is much better, as it's easier to keep an eye on the
code and to make any changes.
Regards,
B.
Tuesday 24 of June 2008 10:06:26 Anne Ghisla napisał(a):
> Hello all, and especially Python plugin developers,
> the interface for my plugin is ready now. Now I have to match its
> buttons/test areas and so on to actions.
> I see that QtDesigner offers some tools to integrate actions inside
> interface, but I've also looked at some available plugins and all actions
> are managed from Python code.
> What do you recommend? Is it Python management easier to write/mantain?
> regards,
> Anne Ghisla
