[Qgis-developer] no Polish chars in table, labels, query results!
Maciej Sieczka tutey at o2.pl
Tue Jun 24 12:31:42 EDT 2008
Marco Hugentobler pisze:
> I tried it with german Umlaute (öüä) and they display ok in the
> attribute table and the query results. If you load from shape, are
> you sure you selected the right encoding in the combo box of the file
> dialog?
I'm using the default 'System' ecoding, which in my case is pl_PL.UTF-8.
If I force 'UTF-8' encodingf at shapefile load still Polish chars are
not displayed - eg. instead of 'zażółć' I get 'za'.
> If you think it is a QGIS related problem, then it is probably best
> to check out a revision from a couple of weeks ago as you suggest:
> svn co --revision {yyyy-mm-dd}
OK. I'll try.
Maciek
Maciej Sieczka
www.sieczka.org
