Fwd: Re: [Qgis-developer] Patch to Remove Qt3 Dependencies
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Wed May 7 03:46:07 EDT 2008
Thanks a lot!
Additionally I found (and commited) that clearing all existing selections in
handleChangedSelections() is always necessary. Because in QTableWidget, it is
now also possible to deselect rows while holding the ctrl key.
Regards,
Marco
Am Mittwoch 07 Mai 2008 08:46:18 schrieb Tom Elwertowski:
> Hi Marco,
> I merged your revision and submitted the patch. checkSelectionChanges also
> needed the revision for deselection.
> Tom
> Marco Hugentobler wrote:
> > Hi Tom,
> > I think I found the reason for the problem with the ctrl - key.
> > Considering all selection ranges in
> > QgsAttributeTable::handleChangedSelections solves the problem:
> > void QgsAttributeTable::handleChangedSelections()
> >   if (lockKeyPressed == false)
> >     //clear the list and evaluate the last selection
> >     emit selectionRemoved(false);
> >   QList<QTableWidgetSelectionRange> selectedItemRanges =
> > selectedRanges(); QList<QTableWidgetSelectionRange>::const_iterator
> > range_it =
> > selectedItemRanges.constBegin();
> >   for(; range_it != selectedItemRanges.constEnd(); ++range_it)
> >       for (int index = range_it->topRow(); index <=
> > range_it->bottomRow(); index++)
> > 	  emit selected(item(index, 0)->text().toInt(), false);
> >   emit repaintRequested();
> > Once you changed this, please commit the patch to svn.
> > Regards,
> > Marco
> > ----------  Weitergeleitete Nachricht  ----------
> > Betreff: Re: [Qgis-developer] Patch to Remove Qt3 Dependencies
> > Datum: Freitag 02 Mai 2008
> > Von: Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch>
> > An: qgis-developer at lists.osgeo.org
> > Hi Tom,
> > I did a bit of testing. In general, things work fine. One problem I
> > encountered is that if multiple entries are selected in the attribute
> > table with holding the ctrl key down, the corresponsing map features are
> > not selected in map view. It works correctly with the shift key.
> > Regards,
> > Marco
> > Am Freitag 25 April 2008 04:43:54 schrieb Tom Elwertowski:
> >> Hello all,
> >> Here is a patch which removes use of Qt3 routines for all of QGIS except
> >> the GRASS plugin:
> >> http://telwertowski.home.comcast.net/qgisqt4_r8378.diff
> >> Please test it and send comments. After resolving any issues, I would
> >> like to submit it to svn trunk.
> >> The GRASS plugin, which probably contains about half of the Qt3
> >> dependencies, will be done later. The patch was done to build with the
> >> Qt/Mac/64bit alpha1 release; Qt3 features are not being ported to
> >> Mac/64bit.
> >> Three categories of changes have be made:
> >> 1. Remove use of qt3support library (Q3 classes).
> >> 2. Remove use of qt3 compatibility routines in qt4 classes.
> >> 3. Remove automatic cast of QString to char*.
> >> Classes and places with non-trivial changes are:
> >> Q3Table to QtableWidget (qgsattributeactiondialog, qgsattributetable,
> >> qgsmeasure) Q3ListView to QTreeWidget (qgsbookmarks,
> >> qgsrasterlayerproperties, qgsgeomtypedialog, qgsserversourceselect)
> >> Q3Dict to QHash (qgsprojectproperty)
> >> Q3Process to QProcess (qgsgpsplugin)
> >> The most complex change involved handling selections in the item view
> >> classes (tables, trees and lists) so this should be tested the most.
> >> In spite of its name, QTreeWidget also handles multicolumn lists which
> >> are not trees; just set rootIsDecoated to false. Qt4 QListWidget is for
> >> lists with one column and no header.
> >> Qt4 has two classes for each item view: QTable/Tree/ListWidget and
> >> QTable/Tree/ListView. The Widget classes contain a backing store and the
> >> View classes don't. The Widget classes correspond more closely to the Q3
> >> classes.
> >> qgsattributetable, which can take a while to load large tables, should
> >> probably be rewritten as a QTableView with an QAbstractTableModel
> >> subclass to pull individual cells directly for the provider as needed.
> >> It has been ported as a QTableWidget to keep the port straightforward
> >> and not introduce additional refactoring into this edit.
> >> Removing automatic casts of QString to char* also uncovered some odd
> >> code. Defining QT_NO_CAST_TO_ASCII will produce a compile error whenever
> >> an implicit QString cast occurs. Based on these two examples, this macro
> >> serves as 'lint' for QStrings.
> >> QString str; delete str; // compiles due to cast of str.
> >> tr("abc" + def + tr("ghi")) // ought to be tr("abc") + def + tr("ghi")
> >> In most cases, I have used toUtf8() to eliminate implicit casts. If a
> >> file already used toAscii(), toLatin1() or toLocal8Bit(), I also used it
> >> to keep the file consistent. Implicit casts have also been removed from
> >> the GRASS plugin so that QT_NO_CAST_TO_ASCII can be defined for all
> >> future builds.
> >> The patch has been tested using Qt4.2, 4.3 and 4.4RC1 as well as
> >> Qt4.4-Cocoa-alpha1.
> >> Tom
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
