cleanups (was Re: [Qgis-developer] Next release name - 'Metis')
Jürgen E. Fischer
jef at norbit.de
Tue May 13 18:38:28 EDT 2008
On Tue, 13. May 2008 at 08:24:22 +0200, Hugentobler Marco wrote:
> It would also be good to make code cleaning sometime, e.g. cleaning
> out old comments and legacy code. I'm however not sure if developers
> have enough time to do that for the next release. I can imagine the
> 'code cleaning festival' one release after the 'performance boosting
> festival' (so probably before 1.0).
I also wanted to address some things:
1. move the remaining debug output using iostream to QgsDebugMsg:
I created a perl script [1], that needs a little patch[2] to fix some
cases the script doesn't handle. After running the script you end up
with patch [3].
2. fix whitespace use (lineendings and identation)
In the repository there are currently not all files using the same
lineending causes problems when diffs are transfered.
I think Tim already prepared an input file for astyle[4] that match
our coding standards. Which could use to get a homogenous look.
At least for me this would be really nice. Most of the time I end up
reformatting code or inventing dumb scripts, instead of doing real work
On Tue, 13. May 2008 at 16:44:49 +0200, Marco Hugentobler wrote:
> If there are no further issues or objections, I plan to merge the
> rendercontext-branch back to trunk on Thursday.
Are there more branches about to be committed? Implementation of the
points above would make it quite hard to merge them...
Jürgen
[1] http://buten.norbit.de/~jef/qgsloggermig.pl
[2] http://buten.norbit.de/~jef/qgslogger-before.diff
[3] http://buten.norbit.de/~jef/qgslogger-after.diff
[4] http://astyle.sourceforge.net/
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
