[Qgis-developer] qgis-grass crash
Paolo Cavallini cavallini at faunalia.it
Sun May 18 16:14:19 EDT 2008
Hi all.
I'm researching on this nasty bug, crashing qgis when opening a grass
vector. I recompiled most of the toolchain from deb-src (from
lenny+debian.gfoss.it), and I still get:
error_routine (fatal = 1): default region is invalid
line 3: <north:      4927864.162>
Cannot open GRASS vector: default region is invalid
*** glibc detected *** qgis: malloc(): memory corruption (fast):
0x00000000017ba4d0 ***
then strace strace says [1]. Does this give a hint of what's happening?
In case it would be useful, I can send a sample data location to
replicate it.
Thanks.
pc
[1]
stat("/home/paolo/.config/QuantumGIS/qgis.conf", {st_mode=S_IFREG|0660,
st_size=15376, ...}) = 0
open("/home/paolo/.config/QuantumGIS/qgis.conf", O_RDWR) = 14
close(14)                               = 0
fstatfs(14, {f_type="NFS_SUPER_MAGIC", f_bsize=32768, f_blocks=8444067,
f_bfree=2143720, f_bavail=2143720, f_files=34324480, f_ffree=33331544,
f_fsid={0, 0}, f_namelen=255, f_frsize=32768}) = 0
fstat(14, {st_mode=S_IFREG|0660, st_size=15376, ...}) = 0
mmap(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1,
0) = 0x2aaab420a000
lseek(14, 0, SEEK_SET)                  = 0
truncate("/home/paolo/.config/QuantumGIS/qgis.conf", 0) = 0
st_size=0, ...}) = 0
write(14, "[General]\nThemes=default\n\n[Bette"..., 15376) = 15376
close(14)                               = 0
munmap(0x2aaab420a000, 32768)           = 0
stat("/home/paolo/.config/QuantumGIS.conf", 0x7fff6481f520) = -1 ENOENT
(No such file or directory)
stat("/home/paolo/.config/QuantumGIS.conf", 0x17522b8) = -1 ENOENT (No
stat("/etc/xdg/QuantumGIS/qgis.conf", 0x7fff6481f520) = -1 ENOENT (No
stat("/etc/xdg/QuantumGIS/qgis.conf", 0x174f558) = -1 ENOENT (No such
file or directory)
stat("/etc/xdg/QuantumGIS.conf", 0x7fff6481f520) = -1 ENOENT (No such
file or directory)
stat("/etc/xdg/QuantumGIS.conf", 0x17522b8) = -1 ENOENT (No such file or
directory)
write(7, "(\0\4\0l\0\0\0\312\5\0\4b\2\376\0", 16) = 16
read(7, "\22\5\241\200\312\5\0\4\312\5\0\4\0\0\0\0\5\0\0\0\0\0\0"...,
32) = 32
read(7, "\n\3\241\200\312\5\0\4\0\0\0\0\0\0\0\0\1\0\0\0\1\0\0\0"..., 32)
= 32
read(7, "\v\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 32)
= 32
= 32
read(7, "\t\5\241\200\32\0\0\4\0\n\205\0\0\0\0\0\220\207V\1\0\0"..., 32)
= 32
= 32
read(7, "\n\5\242\200\32\0\0\4\0GP\0\0\0\0\0\352\254X\0\0\0\0\0"..., 32)
= 32
= 32
read(7, "\t\3\242\200\32\0\0\4\0\0\0\0\0\0\0\0\10\0\0\0\0\0\0\0"..., 32)
= 32
= 32
read(7, "\241 \242\200\32\0\0\0045\1\0\0)\1\0\0\0\0\0\0009\272@"..., 32)
= 32
read(7, "\34\0\242\200l\0\0\0u\1\0\0\250\214\10\1\0\265\241\0\0"..., 32)
= 32
read(7, "\34\0\242\200l\0\0\0\253\1\0\0\250\214\10\1\0\265\241\0"...,
32) = 32
read(7, "\34\0\242\200l\0\0\0t\1\0\0\250\214\10\1\0\v\242\0\0\0"..., 32)
= 32
read(7, "\f\0\242\200\32\0\0\4\373\0(\0l\1\1\0\3\0\0\0\0\0\0\0\240"...,
32) = 32
read(7, "\f\375\242\200\32\0\0\4\372\0)\0n\1\1\0\2\0\203\0\0\0\0"...,
32) = 32
read(7, "\f\0\242\200\32\0\0\4\371\0*\0p\1\276\0\1\0\204\0\0\0\0"...,
32) = 32
read(7, "\f\207\242\200\32\0\0\4\372\0\350\0n\1\1\0\0\0\202\0\0"..., 32)
= 32
read(7, "\25\0\242\200\312\5\0\4\312\5\0\4l\0\0\0\377\0c\0\0\0\0"...,
32) = 32
read(7, "\34\0\242\200\312\5\0\4n\0\0\0\250\214\10\1\0oM\2\0\0\0"...,
32) = 32
read(7, "\34\374\242\200\312\5\0\4\1\1\0\0\250\214\10\1\1\374\245"...,
32) = 32
read(7, "\34\374\242\200\312\5\0\4\260\1\0\0\250\214\10\1\1\374"..., 32)
= 32
read(7, "\34\374\242\200\312\5\0\4j\1\0\0\250\214\10\1\1\374\245"...,
32) = 32
read(7, "\34\374\242\200\312\5\0\4\262\1\0\0\250\214\10\1\1\374"..., 32)
= 32
read(7, "\34\374\242\200\312\5\0\4\234\1\0\0\250\214\10\1\1\374"..., 32)
= 32
read(7, 0x7fff64820130, 32)             = -1 EAGAIN (Resource
temporarily unavailable)
poll([{fd=7, events=POLLIN, revents=POLLIN}], 1, -1) = 1
read(7, "\1\1\243\200\0\0\0\0\0\0\0\0c\1\233\0\0\0\0\0\0\0\0\0\0"...,
32) = 32
write(7, "(\0\4\0l\0\0\0\32\0\0\0049\2\366\0", 16) = 16
read(7, 0x7fff6481ff90, 32)             = -1 EAGAIN (Resource
read(7, "\1\1\244\200\0\0\0\0\0\0\0\0003\2\273\0\0\0\0\0\0\0\0\0"...,
32) = 32
write(7, "&\0\2\0l\0\0\0", 8)           = 8
read(7, 0x7fff6481ff40, 32)             = -1 EAGAIN (Resource
read(7, "\1\1\245\200\0\0\0\0l\0\0\0\362\216\0\0018\3;\0018\3;\1"...,
32) = 32
write(7, "\2\0\4\0\312\5\0\4\0@\0\0\27\0\0\4(\0\4\0l\0\0\0\312\5"...,
32) = 32
read(7, 0x7fff6481fd30, 32)             = -1 EAGAIN (Resource
read(7, "\1\1\247\200\0\0\0\0\0\0\0\0:\1\223\0$\372\t\0\0\0\0\0"..., 32)
= 32
access("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso",
O_RDONLY|O_NONBLOCK|O_DIRECTORY|0x80000) = 14
fstat(14, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
getdents(14, /* 3 entries */, 32768)    = 80
F_OK) = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/./WIND",
0x7fff64820aa0) = -1 ENOENT (No such file or directory)
F_OK) = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/../WIND",
F_OK) = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/WIND",
{st_mode=S_IFREG|0644, st_size=364, ...}) = 0
getdents(14, /* 0 entries */, 32768)    = 0
close(14)                               = 0
stat("/etc/localtime", {st_mode=S_IFREG|0644, st_size=2652, ...}) = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box",
F_OK) = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/frmt",
F_OK) = -1 ENOENT (No such file or directory)
access("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/head",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/head",
O_RDONLY) = 14
fcntl(14, F_GETFL)                      = 0x8000 (flags
O_RDONLY|O_LARGEFILE)
fstat(14, {st_mode=S_IFREG|0644, st_size=172, ...}) = 0
0) = 0x2aaab420a000
lseek(14, 0, SEEK_CUR)                  = 0
read(14, "ORGANIZATION: \nDIGIT DATE:   \nDI"..., 32768) = 172
read(14, "", 32768)                     = 0
close(14)                               = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/topo",
access("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/topo",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/topo",
O_RDONLY) = 14
fstat(14, {st_mode=S_IFREG|0644, st_size=364, ...}) = 0
0) = 0x2aaab420a000
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/coor",
{st_mode=S_IFREG|0644, st_size=128, ...}) = 0
read(14, "\5\0\5\0\0\216\0\0\0\0\212[Cr\230qRA\255\346\20\35\311"...,
32768) = 364
lseek(14, 364, SEEK_SET)                = 364
close(14)                               = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/cidx",
{st_mode=S_IFREG|0644, st_size=113, ...}) = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/cidx",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/cidx",
O_RDONLY) = 14
fstat(14, {st_mode=S_IFREG|0644, st_size=113, ...}) = 0
0) = 0x2aaab420a000
read(14, "\5\0\5\0\0\t\0\0\0\2\0\0\0\0\0\0\0\1\0\0\0\1\0\0\0\1\0"...,
32768) = 113
lseek(14, 113, SEEK_SET)                = 113
close(14)                               = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/dbln",
O_RDONLY) = 14
fstat(14, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
0) = 0x2aaab420a000
close(14)                               = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/hist",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/vector/box/hist",
O_RDONLY) = 14
fstat(14, {st_mode=S_IFREG|0644, st_size=160, ...}) = 0
0) = 0x2aaab420a000
close(14)                               = 0
open("/home/paolo/.config/QuantumGIS/qgis.conf", O_RDONLY) = 14
close(14)                               = 0
0) = 0x2aaab420a000
read(14, "[General]\nThemes=default\n\n[Bette"..., 32768) = 15376
close(14)                               = 0
stat("/home/paolo/.config/QuantumGIS.conf", 0x7fff64820640) = -1 ENOENT
stat("/home/paolo/.config/QuantumGIS.conf", 0x1753818) = -1 ENOENT (No
stat("/etc/xdg/QuantumGIS/qgis.conf", 0x7fff64820640) = -1 ENOENT (No
stat("/etc/xdg/QuantumGIS/qgis.conf", 0x1753818) = -1 ENOENT (No such
file or directory)
stat("/etc/xdg/QuantumGIS.conf", 0x7fff64820640) = -1 ENOENT (No such
file or directory)
stat("/etc/xdg/QuantumGIS.conf", 0x1753818) = -1 ENOENT (No such file or
directory)
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/box",
0x152b928) = -1 ENOENT (No such file or directory)
lstat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/box",
0x7fff648207c0) = -1 ENOENT (No such file or directory)
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT",
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso",
stat("/home/Documenti/Didattica/2008_Portogallo/grass",
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso",
F_OK) = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/./WIND",
0x7fff64820110) = -1 ENOENT (No such file or directory)
F_OK) = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/../WIND",
F_OK) = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/WIND",
close(14)                               = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box",
F_OK) = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box",
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/dbln",
F_OK) = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/frmt",
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/head",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/head",
O_RDONLY) = 14
0) = 0x2aaab420a000
close(14)                               = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/topo",
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/topo",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/topo",
O_RDONLY) = 14
0) = 0x2aaab420a000
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/coor",
32768) = 364
close(14)                               = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/cidx",
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/cidx",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/cidx",
O_RDONLY) = 14
0) = 0x2aaab420a000
32768) = 113
close(14)                               = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/dbln",
O_RDONLY) = 14
0) = 0x2aaab420a000
close(14)                               = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/hist",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/hist",
O_RDONLY) = 14
0) = 0x2aaab420a000
close(14)                               = 0
F_OK) = 0
F_OK) = 0
O_RDONLY) = 14
0) = 0x2aaab420a000
close(14)                               = 0
F_OK) = 0
O_RDONLY) = 14
0) = 0x2aaab420a000
32768) = 364
close(14)                               = 0
F_OK) = 0
O_RDONLY) = 14
0) = 0x2aaab420a000
32768) = 113
close(14)                               = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/coor",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/vector/box/coor",
O_RDONLY) = 14
fstat(14, {st_mode=S_IFREG|0644, st_size=128, ...}) = 0
0) = 0x2aaab420a000
read(14, "\5\1\5\1\0\16\0\0\0\0\200\0\0\0\r\5\0\0\0)\16wx\302.9A"...,
32768) = 128
lseek(14, 128, SEEK_SET)                = 128
O_RDONLY) = 15
fstat(15, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
0) = 0x2aaab4212000
read(15, "", 32768)                     = 0
close(15)                               = 0
munmap(0x2aaab4212000, 32768)           = 0
F_OK) = 0
O_RDONLY) = 15
fcntl(15, F_GETFL)                      = 0x8000 (flags
fstat(15, {st_mode=S_IFREG|0644, st_size=160, ...}) = 0
0) = 0x2aaab4212000
lseek(15, 0, SEEK_CUR)                  = 0
stat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/box/1_polygon.qml",
0x1784f18) = -1 ENOENT (No such file or directory)
lstat("/home/Documenti/Didattica/2008_Portogallo/grass//Toscana_corso/PERMANENT/box/1_polygon.qml",
0x7fff648208d0) = -1 ENOENT (No such file or directory)
F_OK) = 0
O_RDONLY|O_NONBLOCK|O_DIRECTORY|0x80000) = 16
fstat(16, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
getdents(16, /* 3 entries */, 32768)    = 80
F_OK) = 0
0x7fff64820750) = -1 ENOENT (No such file or directory)
F_OK) = 0
F_OK) = 0
getdents(16, /* 0 entries */, 32768)    = 0
close(16)                               = 0
access("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/DEFAULT_WIND",
F_OK) = 0
open("/home/Documenti/Didattica/2008_Portogallo/grass/Toscana_corso/PERMANENT/DEFAULT_WIND",
O_RDONLY) = 16
fcntl(16, F_GETFL)                      = 0x8000 (flags
fstat(16, {st_mode=S_IFREG|0644, st_size=181, ...}) = 0
0) = 0x2aaab421a000
lseek(16, 0, SEEK_CUR)                  = 0
lseek(16, 0, SEEK_SET)                  = 0
read(16, "proj:       99\nzone:       0\nnor"..., 32768) = 181
read(16, "", 32768)                     = 0
open("/usr/lib/grass//locale/it_IT.UTF-8/LC_MESSAGES/grasslibs.mo",
O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/grass//locale/it_IT.utf8/LC_MESSAGES/grasslibs.mo",
open("/usr/lib/grass//locale/it_IT/LC_MESSAGES/grasslibs.mo", O_RDONLY)
open("/usr/lib/grass//locale/it.UTF-8/LC_MESSAGES/grasslibs.mo",
open("/usr/lib/grass//locale/it.utf8/LC_MESSAGES/grasslibs.mo",
open("/usr/lib/grass//locale/it/LC_MESSAGES/grasslibs.mo", O_RDONLY) =
close(16)                               = 0
munmap(0x2aaab421a000, 32768)           = 0
write(2, "error_routine (fatal = ", 23error_routine (fatal = ) = 23
write(2, "1", 11)                        = 1
write(2, "): ", 3): )                      = 3
write(2, "default region is invalid\nline 3"..., 59default region is invalid
line 3: <north:      4927864.162>) = 59
write(2, "\n", 1
)                       = 1
write(2, "Cannot open GRASS vector: ", 26Cannot open GRASS vector: ) = 26
write(2, "\n", 1
)                       = 1
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
Process 25935 detached
Paolo Cavallini, see: * http://www.faunalia.it/pc *
