[Qgis-developer] Mapserver Exporter Bug?
Mauricio de Paulo mauricio.dev at gmail.com
Fri May 30 12:41:52 EDT 2008
Ok....
I think i know how to fix this. Hum... i'd like to hear from the mapserver
exporter manteiner if i have permission to alter his code more.
Until now i've been changing my file and sending him the modifications. I wish
these fixes were implemented on the version available in the repository.
As soon as I get this permission (or some other way of sending him the fixes
I'll be back to mapserver exporter's bug busting. :D
Maurício de Paulo
On Thursday 29 May 2008 20:06:27 John C. Tull wrote:
> Mauricio,
> I get the following error now, but this may be related to some layers
> with no names because a partial file is being written. Let me play
> some more...
> An error has occured while executing Python code:
> Traceback (most recent call last):
>   File "/Users/jctull/.qgis//python/plugins/mapserver_export/
> mapserverexport.py", line 94, in run
>    result = exporter.writeMapFile()
> ms_export.py", line 101, in writeMapFile
>    self.writeMapLayers()
> ms_export.py", line 283, in writeMapLayers
>    self.outFile.write("  NAME '" +
> lyr.getElementsByTagName("layername")
> [0].childNodes[0].nodeValue.encode('utf-8').replace("\"", "") + "'\n")
> IndexError: list index out of range
> Ok, this is because there were some layers (rasters) that had no name.
> When I drag and drop rasters, they come in with no name, but I place
> them in a group folder, so never change them. This led to the above
> problem.
> John
> On May 29, 2008, at 3:38 PM, Mauricio de Paulo wrote:
> > Please, can you test this mapserverexport update? I've written the
> > str()
> > function on every qwidget that might need the type cast. And i did
> > some other
> > fix that i don't remember (hum... i think that it was the exporter
> > wrong
> > layers' ordering)
> > Hope it works.
> > See ya.
> > Maurício de Paulo
> > On Thursday 29 May 2008 17:18:24 John C. Tull wrote:
> >> I get the same error on OS X, but the suggested change to line 81 did
> >> not fix this for me.
> >> John
> >> On May 27, 2008, at 3:42 PM, Mauricio de Paulo wrote:
> >>> Hi everybody,
> >>> I was working with mapserver exporter and ran into a problem with
> >>> the error
> >>> message at the end of this mail.
> >>> After a little debug i found out that the code was passing a QString
> >>> instead
> >>> of a python string when reading the filename from the dialog. This
> >>> is a
> >>> regular source of bug as some classes don't understand QStrings very
> >>> well,
> >>> even though they do work a lot like python strings.
> >>> After the change on mapserverexport.py on line 81:
> >>> exporter = Qgis2Map(str(self.dlg.ui.txtQgisFilePath.text()),
> >>> str(self.dlg.ui.txtMapFilePath.text()))
> >>> I don't know exactly if only my python and pyqt versions require
> >>> this but it
> >>> fixed the problem for me. I think it's a good idea to NEVER work
> >>> with
> >>> QString, just with python strings for compatibility purposes.
> >>> versions:
> >>> Python 2.5.2
> >>> PyQt4.QtCore.qVersion() '4.3.4'
> >>> qgis 0.10.0
> >>> Ubuntu 8.10
> >>> Thanks for the good work with Mapserver Export Plugin. I've been
> >>> working with
> >>> it for 2 years now and it fills a great gap in the mapfile
> >>> production.
> >>> Maurício de Paulo
> >>> File "/home/vatto/.qgis//python/plugins/mapserver_export/
> >>> line 81, in run
> >>> exporter = Qgis2Map(self.dlg.ui.txtQgisFilePath.text(),
> >>> ms_export.py", line
> >>> 37, in __init__
> >>> self.qgs = minidom.parse(projectFile)
> >>> File "/usr/lib/python2.5/xml/dom/minidom.py", line 1915, in parse
> >>> return expatbuilder.parse(file)
> >>> File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 928, in
> >>> parse
> >>> result = builder.parseFile(file)
> >>> File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 204, in
> >>> parseFile
> >>> buffer = file.read(16*1024)
> >>> AttributeError: read
> >>> W
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > <mapserverexport.py>
