[Qgis-developer] Win32 Build Problem
Jürgen E. Fischer jef at norbit.de
Fri May 30 18:28:59 EDT 2008
Hi Rob,
On Fri, 30. May 2008 at 11:50:40 -0600, Rob McCulley wrote:
> I'm trying to build qgis using MSVC 8 on windows xp, and I've run into a
> bit of a problem.  My qgis source is from svn, and for dependencies, I'm
> using the qgislibs-release package from the wiki. All of the components
> build successfully except qgis itself.  These are the errors I get:
I think the qgislibs package is build in release mode.  I that case you
should build qgis using the Release or RelWithDebInfo instead of Debug
configuration.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
