[Qgis-developer] Proposal: Lift feature freeze for labelling
Tim Sutton tim at linfiniti.com
Fri Oct 3 14:54:36 EDT 2008
Hi
2008/10/3 Magnus Homann <magnus at homann.se>:
> Interesting, but sounds like a it needs some man-hours. What's the time
> frame?
I'll tell you after more detailed discussions with them tomorrow :-P
> As a side question, is there possibilit to have labels manually placed and
> position saved in QGis?
I was also thinking about this. We will have quite a bit of
flexibility in this regard I think since the label placement lib need
not be passed all labels. To explain better: if a user uses e.g. a
table attribute to fix the label to a specific location, we could
consider the bounding box of the label a 'feature' that other labels
need to place themselves around....once again we will probably have a
better idea about the possibility of doing this after tomorrow.
Regards
Tim
> Magnus
> Magnus Homann
> magnus at homann.se
> +46 702 399 558
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
