AW: Re: [Qgis-developer] PostGIS Query Builder doesn't allow Queries with 0 result records
Düster Horst Horst.Duester at bd.so.ch
Wed Sep 3 06:54:34 EDT 2008
Hi Jürgen
Thank you very much. Now it works and I can't see any problems at the
moment.
Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Jürgen E. Fischer [mailto:jef at norbit.de]
Gesendet am: Mittwoch, 3. September 2008 12:35
An: qgis-developer at lists.osgeo.org
Betreff: Re: [Qgis-developer] PostGIS Query Builder doesn't allow
Hi Horst,
On Wed, 03. Sep 2008 at 10:39:49 +0200, Düster Horst wrote:
> I do have the following scenario:
> Within a data capturing project I want to reduce the number of visible
> objects for a single digitizing person. This person only should see
the
> objects digitized by himself in a defined area. At the beginning of
the
> digitizing work, of course, no objects are belonging to this person.
As
> the result I'm not able to define an according query due to the
> limitation "QGIS needs in minimum 1 Object to work".
> Is this limitation mandatory?
I think there is no such limitation as you can add empty table just
fine.  The message only appears if you try to filter, therefore I
removed it in r9253.  Please let me know if this causes any problems.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel.
+49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
+49-4931-918175-50
Software Engineer         D-26506 Norden
http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080903/9d618b22/attachment-0001.html
