[Qgis-developer] Import error in the qgis.core, qgis.gui module, Help needed
Marco Pasetti marcopstt at gmail.com
Thu Sep 4 03:22:56 EDT 2008
Hi all,
>>I am a newbie in this environment (python, QGIS). For last few days  i
>>have
>>been trying hard to compile and execute the tutorial of TIM written in
>>python. But i am getting some error or other.
>Try adding the path to the python directory within your QGIS install to
>your PYTHONPATH environment variable.
The Quantum GIS package for windows comes with all the files (QT and Python)
needed to execute the python plugins, but if you want to develop new python
applications within QGIS you probablly would need more libraries than the
ones bundled in the current distributed package. This said, if you installed
Python on your windows machine you should not need anything else, because
python itself set its python environmental variable during the install
procedure. If you're encountering some errors with Python, that may be
generated by different problems that would need to be more accurately
investigated. You'r referring to a "Tim's tutorial", what exactly?
Regards,
Marco Pasetti
